hey - relative noob (just use dvddecrypt / dvdshrink / ifoedit / then nero to burn dvds)
im having problems with one dvd. when i run the VOBS through ifoedit, it says there are no problems. however when i open the VOBS in WMP or burn it to disc, the audio is about a half second behind.
the original dvd plays fine...![]()
I take it you mean rip/shrink DVDshrink , burn Nero and then you are peeking/adjusting with IFOedit .
Try ripping and shrinking it with another package , there are plenty of trials around of various packages . This`ll tell you if its your ripping and shrinking causing it . WMP is a strange beasty - it can adjust itself to play files (which are out of synch ) in perfect synch , but your prob is the other way around , which is also a speciality of WMP - ie dont trust it.
Are you playing the new dvd back on your dvd player or on your pc ? try it on a dvd player
And try another burning package . -
i have the same problem with 1 dvd that i have, the auido is about half
a second behind the movie, which makes the movie unwatchable.
i dont know what program to use to fix the audio synch.
can someone please help me.
thanks.
(i have the files in vob on my hdd)
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 6th Mar 2009, 23:46 -
Conversion to FLV - ffmpegx doesnt work
By indianiec in forum Video ConversionReplies: 3Last Post: 17th Jan 2008, 00:36 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 09:05 -
Member Status......doesnt work
By electricsguy in forum FeedbackReplies: 14Last Post: 25th Jun 2007, 10:21
