Would appreciate comments on expected conversion times.
I am capturing my old VCRs with an ATI8500 AIW card direct to mpeg2. For good quality tapes this seems to work well. however some of the VCR captures need to be improved; so I am trying to filter in virtualdubMod and frameserve to TMPGenc Pro. This process reports an estimated time of 30 hours for one 4.3GB Mpeg2 file. My PC is a 2.2GHz pentium 4 running XP pro with 1GB memory and a 7200rpm HD with 75 GB free on an E drive. The drives are served by a Promise Ultra ATA/133 controller. The CPU is running at 100%. Is this time normal? The ATI capture/conversion to mgeg2 is in real time, but filtering is weak.
Carl D
Is the 30hrs just for TMPGEnc ? That sounds way too long for mine given your PC specs. Having said that, by the time you put filters on, it could take a while. You don't mention the length of the MPEG-2 files timewise or what rate control you are using. These will have an effect on encoding times.
If in doubt, Google it. -
It depends, in large part, on the settings in TMPGenc that you are using. I have a slightly slower P4 system than you do, and it took me about 15 hours to encode about 1 hour of DV footage. I was using the "high-quality TMPGenc" settings specified in the guide on this site (2-pass VBR). Can you specify which settings you are using in TMPGenc?
subtitles do not play after proccessing with the mkvmerge GUI for mktoolnix
By arconreef in forum SubtitleReplies: 4Last Post: 29th Oct 2010, 22:34 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 14:08 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 17:48 -
various time codes on miniDV. Want one time code.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 22:08 -
Can Not Do More Than 1 At A Time
By rfleisch in forum ffmpegX general discussionReplies: 2Last Post: 25th Oct 2007, 12:29
