I am running an Athlon xp1500 with 256MB ram for decoding reauthoring etc would adding more ram speed the process significantly.Also my 40 Gb harddrive which was ample now seems pitifully small what size would you recomend if i were to upgrade.
If your encoding speed is being slowed by not enough memory, adding the maximum amount of memory will take care of that. It always is a good idea, although a speed increase is not guaranteed. Next, make sure your secong hard drive is at least 80 GB, 120 GB is even better.
Keep both drives defragged, and if you can install an IDE card for the second drive to run from, it helps as well. Use the 40 GB for applications only, and the second drive for video only, if possible. There are other ideas as well, but these are the ones that come to mind. Hope this helps.
Hello. -
YES, go for 512, if you have the money, 1G is awsome, and 120GB hdd, and if you can affort, 160 or higher...you won't regret it.
No. Significant increase in speed means CPU upgrade.Originally Posted by mikey388
You can never have enough HD space when you're doing this stuff. I'd keep the 40 GB drive and run your OS from it and add at least an 80 GB drive to use for capturing & editing/encoding/compiling. Use the extra space on the smaller drive to store stuff untill you can burn it to disc, and try to keep the big drive empty.Also my 40 Gb harddrive which was ample now seems pitifully small what size would you recomend if i were to upgrade."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
PC memory
By alintatoc in forum ComputerReplies: 17Last Post: 17th Nov 2009, 17:24 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
