Does anyone know if TMPGENC Plus 2.5 is good at encoding only AVI files or is it useful to re-encode an existing MPEG-2 file to a smaller size?
The reason I ask is because it would free up room on my hard drive if I all I had to re-encode would be an MPEG-2 file captured at a high, constant bitrate. 8)
as long you have right codec installed on your machine and the right .vfp in the Tmpgenc you can re-encode xvid, divx, avi, mpg1 and mpg2. also quick time .mov.
the .vfp that I use are:
DVD2AVI.vfp - for all AVIs(comes with DVD2AVI) just copy into Tmpg folder.
M2v.vfp - for mpg2.
QTReader.vfp - for Quick Time.
I dont know if these .VFPs are available here somewhere on the left but just do a google search on those VFPs and you should find them to d/l
hope this helps
TMPGenc 4.0 Xpress can't encode AVI with 16:9 display
By Sanderverbeke in forum DVD RippingReplies: 2Last Post: 23rd May 2010, 07:21 -
Does anyone got idea to encode VC-1 to Mpeg2?
By Dboyz in forum Newbie / General discussionsReplies: 2Last Post: 3rd Sep 2009, 08:07 -
Encode uncompressed AVI to MPEG2 (Best method?)
By abvision in forum Video ConversionReplies: 14Last Post: 9th Jun 2009, 03:11 -
Cut parts out of a mpeg2 without having to re-encode?
By ltd. in forum EditingReplies: 7Last Post: 23rd Dec 2008, 17:21 -
Better format to encode to: MPEG2 or DivX/AVI?
By Grunberg in forum Video ConversionReplies: 15Last Post: 15th Feb 2008, 08:29
