Results 1 to 18 of 18
  1. I, recently, got a TDK dvd-rw, metalic gray top.
    tried to burn some data, but Toast (5 and 6) gave me this error:
    The drive reported an error:
    Sense Key= BLANK CHECK
    Sense Code= 0x00
    NO ADDITIONAL SENSE INFORMATION
    What could be the problem here?
    Thanks,
    eMac
    SuperDrive PIONEER DVD-RW DVR-104, Device Revision A227
    Mac OS X 10.2.6
    Toast 5, 6
    artistic treatment of mortality
    Nov 2003
    New New York, Year 3000
    BLANK CHECK
    and
    are pretty damn funny errors. Did you buy more than one disk? Have you tested another DVD-RW to see if you drive has issues with them?
    If it isn't broken, take it apart and find out why.
    blog: deadsierra
  3. are pretty damn funny errors. Did you buy more than one disk? Have you tested another DVD-RW to see if you drive has issues with them?
    I bought only one disc to test to see if it works w/ my drive.
    Have not tested any other.
    do you think this is brand-related problem ?
    Thanks.
    Nov 2003
    I'm thinking its a specific disk error. Is it possible for you to test a variety of of media?
    blog: deadsierra
  5. Originally Posted by deadsierra
    The media could be the problem. Even if this is the case, is not toast suppose to give an error something like "Sense Key= MEDIUM ... "?
    I should try different brands as you suggested.
    Let me ask people w/ SuperDrive PIONEER DVD-RW DVR-104, Device Revision A227, What brand and version dvd-rw are you using?
    Thanks.
  6. I messed up my first disc too, . . . forgot to read the part where it said I had to format the disc first.
    May God bless,
    Dwight
    Dec 2003
    Eugene, Oregon
    Dwight, what are you talking about? There is no disc formatting that is done first with Toast or with Apple's Finder disc burning.
  8. Originally Posted by Frobozz
    I agree.
    The disc in question is a TDK dvd-rw, metallic gray top.
    item code: DVD-RW47EA.
  9. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    surprising... especially from that media brand. I have never tried thier -rw line only the -r [which have always preformed solidly for me] that said i would think these -rw would do the same
    is this the kind you have? Its the ONLY -rw that TDK makes so if its not perhaps you have a knockoff passing as TDK?!?!?
  10. Originally Posted by galactica
    Galactica,
    I forgot to mention that I am in region 2.
    Packaging is different in Europe. If you have time, could you please click the link below that leads to the image of the disc.
    http://www.tdk-europe.presscentre.com/imagelib/loadimage.asp?media_id=633
    this is the exact disc I have.
    Thanks.
  11. Frustrated... I tried NTI Dragon Burn X w/ the TDK DVD-RW I have.
    it gave me this error:
    Errors Occured During Write!
    BE Error- Sense Error
    ((03h, 31h, 00h), Medium Error, Medium format corrupted)
    Anyone would like to comment on this ?
    Dec 2003
    Eugene, Oregon
    I think I know the problem. If this is the eMac superdrive then it can only write to DVD-R media. It cannot write to DVD-RW. It doesn't matter that Pioneer supports DVD-RW with this drive because Apple is using firmware that prevents the use of DVD-RW media. Some folks have found a way to change this firmware (which may result in Apple refusing to repair it under warranty). Search for information about this at xlr8yourmac.com.
    Mar 2005
    Canada
    Hi everyone,
    this is my first post so I hope I'm doing it in the right place. A few days ago I also received the exact same error message from toast (ver 6.09) The drive reported an error:
    Sense Code= 0x00
    Unlike the other poster, I was using a DVD-R (verbatim 8X media). This happened after toast seemed to be stuck (the progress bar wasn't moving, so I quit the app...of note, toast didn't give me the "application not responding message" so it, the application, wasn't "frozen"). This occurred while I was backing up a movie...not sure if this detail matters. Finally, I received the error from toast after I immediately tried to burn the movie again. I finally did manage to burn the movie at 8x (although toast again seemed to be stuck. Also, after another failure (similar error message from toast) I've been able to burn at 4X (same media). Sorry if this message is a little long, any help is appreciated.
    P.S The burner is a Pioneer 108 firmware 1.17
    computer Blue & white 450
    OS 10.3.7
  14. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Its saying the 'so called' DVD-RW or R isn't BLANK, because
    Sense Code= 0x00
    This is a SCSI device error that decodes as follows:
    A BLANK CHECK ERROR OCCURS WHEN
    Indicates that a write-once device or a sequential- access device encountered blank medium or format-defined end-of-data indication while reading
    or
    a write-once device encountered a non-blank medium while writing
    Remember even an ATAPI device like the PIONEER A04 is considered a SCSI device in this regard
    (ATAPI stands for Atatchment to an AT computer peripheral interface..but now we gott'em in our macs)
    (IDE -Integrated drive electronics) (SCSI small computer serial interface)
    Idunno if this helps..but its all true
    Mar 2005
    Canada
    Thank you dcsos for your reply,
    I think I understand your explanation, but maybe I don't...let me ask you this; do you think this is a media issue or a problem with my burner? Up until just the other day it was working fine with burning 8X Verbatim
    DVD-R's. Could it be that I've reached a point in the spindle where there are some doggy ones? It would be nice to know if the problem is the burner...it's still under warranty. Finally, any thoughts about upgrading the firmware? Would that do the trick...any thoughts? Thanks again for any help.
  16. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    I'm going to hazard a guess:
    I think its a minor incompatibility between TOAST and the drive.*
    I think If you made a disk image (.ISO)
    and burned that with DISC BURN the incompatibility would not be an issue as I think its possible the APPPLE knows your drive (and where the blank bits are on any brand of disc you throwin it..unlike Toast)
    this was a guess
    *this might well be fixble with firmware upate, but might not..(I'd try getting the full drive replaced---firmware updated already on the new one if i could)
    Mar 2005
    Canada
    Thanks again dcsos
    I'm going to give your suggestion a whirl I'll report back with some results. I guess I should also try some different media too. Finally (I mean it this time :P ) someone told me it could be a data transfer issue...the drive is internal Master on the cd ata bus (I also have my dvd mastering hard drive attached to the same bus as a slave) any thoughts?
    P.S Before any new rip I always erase the hard drive (with disk Utility), so fragmentation should not be an issue. Thanks again for all your help.
  18. Member
    Mar 2005
    Canada
    Hi dcsos,
    so I took your suggestion and used Disc Utility (I used DVD Imager to make an img of a ripped DVD) to see if I could burn at 8x (using Verbatim). First off, Disc Utility would not let me change the burn speed...it stayed greyed out at "Best" which for some reason is 12x...Toast also gives me this speed choice for some reason. Anyway, the burn should have taken 6 Min, but in actuality took over 17 min!! The burn seems fine but I still have no idea what's going on here...anyone have any ideas? Thanks.
