Hi, I just got a New ATI All in Wonder 128 pro (32 Meg AGP), And I try to hook up my Stand alone DVD play to the Video In Port(S Video, and it showed up on my computer but it was a mix of green and pink! Is there any way to get around that, Like a Program? And Also if I can't I was thinking about getting a DVD Rom for my COmputer (I have a 1400 with 256meg DDR Ram) and I wanted to know what the best one to get, Need it to be the fastest around, I am going to use it to rip DVDs? Any help would be nice, Thanks
I've got the same card and I've tried a couple of times to capture a DVD from my stand-alone player with ATI MMC via svideo or composite, the result was the same: in playback everything goes fine for some time, then audio keeps going on while video repeats the last couple of seconds for a lot of times, then goes on well, then again .....
A friend of mine has an ASUS card, he says he can capture DVDs with no problem ...
Sorry I can't help, if I discover something I'll tell you -
sounds like macrovision to me. go to doom9's site, download the ATI de-macrovision program and see if that works for you
I'm not promising anything but it is an option -
The disable-macrovision thing didn´t work on my machine, although I have ALL of the pre-reqs.... oh well...
I´ve been looking around for a solution, so far with little success... The only thing I found that might help is an extra gimmick: the SIMA COPYMASTER SED-CM. There are other similar alternatives, but a lot of people seem to believe this little box is the way to go. Look it up in Circuit City...
Good luck, and if you find a solution POST IT!!
E.Baldino -
I have ATI All in wonder VE, what macrovision? is it bad?
»®»ŦħĄňķŜ«®«
»®»Life Is Góód«®«
»®»Its All Gööd«®« -
Hey Operationz, I went to http://www.doom9.net/(I guess that's the right one?) and looked for ATI de-macrovision program , BUt I found no program with ati in it. Is it call something else? Thanks for your help
TitaniumDragon2001, send me an email or make your email address visible. I'll send you the program then
I had a problem with macrovision but the registry-patch from http://www.doom9.org fixed it!
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum CapturingReplies: 15Last Post: 1st Jan 2011, 18:41 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum CapturingReplies: 8Last Post: 31st Mar 2009, 11:26 -
ATI 7500 AIW capture problems
By saoneg in forum CapturingReplies: 8Last Post: 6th Mar 2008, 05:11 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum CapturingReplies: 23Last Post: 18th Nov 2007, 01:24 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum CapturingReplies: 2Last Post: 6th Aug 2007, 16:49
