  1. hi ppl
    im sure many of you as i have are a little unhappy with the quality of our captures simply due to poor assets. even with a good capture rig and process there is nothing you can do about poor quality video.
    can anyone give me some info about enhancing video in post, specifically noise removal filters, color correction and anything that is going to help with improving video quality.
    i need to remove interference artifacts (on the original tape), is there a way to edit frame by frame in premiere, copying portions from the previous frame and blending into the current frame to block out the offending artifact.
    thanks for your time....tak
    The guides at my site describe the whole process.
    However I botched up some of the site while changing servers, so it'll be down for about another week.
