I was just wondering if ALL NTSC DVD players support 352x480 DVD resolution. I wanted to record some TV Episodes that I have onto a DVD+R and was just wondering if I was going to have any problems. And also, if there is anything special I have to do for 352x480 resolution to work on my DVD player. Thanks very much in advance for any help.
Results 1 to 15 of 15
Idioteque74
352x480 is part of the DVD spec and should be supported by any NTSC DVD player.
Keywords: should be
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Just remember that that resolution is for a MPEG2 encoded stream. MPEG1 is only 352x240.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
As wulf108 said ... a resolution of 352x480 is completely safe to use as it is part of the official DVD spec.Originally Posted by Idioteque74
As for Apex players ... they are crap ... lucky they work at all :P
As for making any changes for 352x480 ... not really. It is the same as using Full D1 resolution (720x480) except of course the benefit of using Half D1 resolution (352x480) is that it requires less bitrate to look good and despite the fact that the resolution is lower with Half D1 it can look nearly as good as Full D1 ... although if you compared them side by side you would notice that Half D1 was a bit "softer" looking then Full D1.
Anyways the one thing you should know about encoding for Half D1 is that it tends to hit the MAX bitrate at around 5000kbps whereas a DVD can have up to approximately 8000kbps for the video.
So I often do a CBR of 5000kbps if that bitrate can be used. If I'm doing something that is long enough that I can't use 5000kbps but need to go with a lower bitrate then I often will do a 2-pass or multi-pass encode.
Also you need to judge this yourself with some testing but in my opinion I don't like to go lower than 3500kbps (and when I go that low then 2500kbps is my AVG in a 2-pass/multi-pass encode). However I should point out that some users seem to think you can get away with a bitrate as low as 2500kbps and still get acceptable quality.
Just to set the record straight here is the NTSC DVD spec ... this is actually on this website if you look hard enough 8)
Only thing I should point out is that technically MPEG-1 Layer2 audio (aka MP2) is not really a part of the official NTSC DVD spec but most NTSC DVD players seem to be able to handle it (knock on wood). So in short you are better off using PCM WAV audio or AC-3 audio.Originally Posted by dvdrhelp.com website
Oh one last thing ... only Full D1 resolution (720x480 and even 704x480) support 16x9 anamorphic encoding/decoding. So for instance you can't make 352x480 16x9 anamorphic and expect the DVD player to handle it properly.
Have Fun
MPEG1-LayerII audio is NOT MP2 audio.Originally Posted by FulciLivesICBM target coordinates:
HUH ?!?!?!Originally Posted by SLK001
I think someone is confused and it is not me :P
- John "FulciLives" Coleman
P.S.
Please note that I did say MP2 ... not MP3 which IS different."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
OK so what is MP2 audio and why do various programs attach a
.MP2 extension to Mpeg 1 layer 2 audio ?
( We will ignore Pinnacle for using MP2 for MPEG2 ) -
thanx very much for all the info...I have a Panasonic DVD-RV31 and not an Apex (got rid of it), so I should be ok. Thanx again!
Idioteque74 -
If the machine in question can't play Half-D1 resolution, it can't receive the 'DVD Logo' from the DVD Forum. Having read their licensing agreement (it's worse than Philips!) that's the conclusion I've drawn.
Except from http://www.tnt.uni-hannover.de/project/mpeg/audio/faq/
What is provided by MPEG-1, MPEG-2, MPEG-4 and MPEG-7 Audio?
MPEG-1 (ISO/IEC 11172-3) provides
single-channel ('mono') and two-channel ('stereo' or 'dual mono') coding of digitized sound waves at 32, 44.1, and 48 kHz sampling rate. The predefined bitrates range from 32 to 448 kbit/s for Layer I, from 32 to 384 kbit/s for Layer II, and from 32 to 320 kbit/s for Layer III.
MPEG-2 BC (ISO/IEC 13818-3) provides
a backwards compatible (BC) multichannel extension to MPEG-1; up to 5 main channels plus a 'low frequent enhancement' (LFE) channel can be coded; the bitrate range is extended up to about 1 Mbit/s;
an extension of MPEG-1 towards lower sampling rates 16, 22.05, and 24 kHz for bitrates from 32 to 256 kbit/s (Layer I) and from 8 to 160 kbit/s (Layer II & Layer III).
MPEG-2 AAC (ISO/IEC 13818-7) provides
a very high-quality audio coding standard for 1 to 48 channels at sampling rates of 8 to 96 kHz, with multichannel, multilingual, and multiprogram capabilities. AAC works at bitrates from 8 kbit/s for a monophonic speech signal up to in excess of 160 kbit/s/channel for very-high-quality coding that permits multiple encode/decode cycles. Three profiles of AAC provide varying levels of complexity and scalability.
Mind you it doesn't mention what MP2 is though... -
MP2 is the 'colloquial' DOS/Win32 filemane extension for MPEG-1 Layer II audio streams. The term 'MP2' was not standardized by either the IEC or MPEG, but was created to fit the 8.3 file structure.
Container Types Compatible with Stand-Alone DVD Players
By Groami Geistalt in forum MacReplies: 5Last Post: 12th Mar 2010, 00:20 -
Making sure AVI is compatible with DVD players
By uniks in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2009, 17:31 -
Is low bit rate mpeg2 (1200kbps) compatible with all DVD players?
By jimdagys in forum Newbie / General discussionsReplies: 7Last Post: 18th Jan 2008, 07:49 -
how to fit more than 2 episodes on a DVD and be compatible with all players
By brentonboy in forum Newbie / General discussionsReplies: 18Last Post: 20th Nov 2007, 02:35 -
AC3 / DivX Compatible Players
By nordicgreen_8 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th May 2007, 07:35
