Hi all,
Although I am a bit used to do some MPEG-2 real-time captures, I have just put my hands on a ADVC-100 converter and I want to learn a bit about DV stuff, so, please forgive me for making basic questions; but I am a newbie when it comes to DV;
1) What type should I use when capturing, type-1 or type-2 ? What is the best ? Should I make any conversion after capturing from 1 to 2 or vice-versa ?
2) Is the sound on both types LPCM ?
3) How can I multiplex/demultiplex video/audio on a DV file ? Is it possible to make it on single tools or may I use a video editor for that ? I think that simply opening the file in SoundForge would allow me to save the WAVE audio as a separate file, but how to do the opposite way, I mean, to multiplex audio/video ? This step is very important for me, as I use to normalize original audio and I need it muxed in back again for further editing,
4) If I load the original DV on Media Studio Pro, for example, can I replace the original audio by other (remastered) wave file ?
5) What sw do you recommend for capturing ? Scenalyzer ? Media Studio Pro ? Adobe Premiere Pro ?
6) Does the CANOPUS ADVC-100 convert the file to Field A (like DV camcorders) or Field B ? Lower Field or Upper field ?
Thanks,
Zetti
Pinnacle Studio 8 and DV home video editing (ver.9 already home)
I use the Capture module in Mediastudio Pro to do the transfer from DV camcorder to hard drive, normalise the levels and clean up the audio using the Audio Editor module in Mediastudio Pro and then don't need to do anything with the audio once I reach the editing stage. To answer your point in question 4, yes you can, but if you use the Audio Editor, you don't have to strip the audio off as a wav, you can play around with it while leaving it as the audio track of the avi.
Newbie bluetooth questions
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2011, 04:37 -
couple newbie questions - DVD to MKV and watch on WDTV
By timmyinnis in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2010, 03:14 -
Newbie questions about HD camcorder etc!
By n33712 in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2009, 14:16 -
Newbie Questions DVD to ????
By swezey in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2008, 09:19 -
Some newbie questions about sirius
By janeydoll in forum AudioReplies: 9Last Post: 10th Jun 2008, 01:19
