When I try to open the template VideoCD (NTSC) in TPGEnc v. 2.5, or any template for that matter, I get the error "Invalid Stream Format". I've searched the forum and found no reference to that error message. Any suggestions? I'm pretty much a newbie, but I have used TPGEnc quite a bit, but I've never tried to customize the settings. Thanks for any help anyone could give.![]()
Lville
You wouldn't be trying to open the template as a video source, would you? That's the only reason I can think of why you would be getting that error. If so, do this instead:
If I'm way off base and completely wrong, I apologize.
Thanks teegee,
I feel really stupid for overlooking something so simple. I appreciate your kind help. Everything worked just as the guide suggested!
Lville
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
(Newbie) Adding subtitles with TMPGEnc 3
By mrwednesday in forum SubtitleReplies: 0Last Post: 2nd Mar 2010, 19:00 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
Newbie assistance. GMC error - how do I fix it?
By JesterDev in forum Video ConversionReplies: 3Last Post: 10th Oct 2008, 12:23 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 11:05
