    Mar 2004
    Bermudas
    Hi ye guru-guys,
    I need help with the follwing problem..
    Got an M2V ripped from a DVD.
    ran this:
    pulldown src.m2v dst.m2v -norff -framerate 23.976 -prog_frames p -aspect_ratio 16:9
    on it; Got a video that has pure progressive frames @ 23.79, 16:9 AR.
    Feed it to Canopus Procoder, which detects that this video is 2:26, which is correct.
    Set the settings as usual (Progr_frames, 4:3, 23.79), reducing bitrate to 5000Max.
    On output got another M2V, which also has progr_frames, 23.976, 4:3 BUT the reported mov length is 1:26!!!! Procoder screwed it up somehow. Attempts to run TMPEGEnc/Merge & Cut result in having another padding stream added into M2V, and Pulldown.exe could not be applied to a file with 2 streams in it.. Not other tools work on this file, like for example ReStream or MPEG Sequence Maker...
    Did I do something wrong? Could It be that the ripped M2V is not quite progressive video pulled down? How could I fix the time on the resulting movie ?
    ~XAWE~
    Mar 2004
    Bermudas
    Originally Posted by XAWE
    Hi ye guru-guys,
    ran this:
    Update: bbdmux tools shows that this is a transport stream?!?!?
    How could Procoder make something like that??? Since when MPEG2 Elementary Stream setting produces a TS?
    ~XAWE~
