Got an NEC DVD+R/+RW burner with my new Dell Pentium 4 PC. The Sonic MyDVD software won't allow me to vary the write speed (the option is grayed out and set to "auto"). So I downloaded TMPGEnc's new DVD Author Trialware. That software ALSO has the write speed option grayed out for DVD burning and is preset to "max". I suspect that since my DVD burner is burning at the max speed that it may be causing the jittery playback on my DVD's which is driving me NUTS. I want to burn at a slower speed to confirm this. I've never heard of a burner that doesn't allow you to vary the write speed so at this point I don't know if I have a software problem or a hardware problem. Dell has been of no help, of course. Does anybody have any suggestions? Should I keep downloading different authoring/burning trialware to see if those software also have the write speed grayed out? If its a hardware problem could I need some sort of new driver?
Many thanks.
Results 1 to 1 of 1
How can I increase DVD/Blu ray write speed?
By gsingh13 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2011, 21:47 -
multi LG Gh22np20 write speed issues
By mistermofo in forum DVD & Blu-ray WritersReplies: 5Last Post: 6th Jan 2010, 18:37 -
Finding out write speed
By BrokenOne in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st May 2008, 01:40 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 12:58 -
change hardware encoding options in AVerTV PVR M116 Plus
By mb508 in forum LinuxReplies: 0Last Post: 19th Sep 2007, 07:14
