Hello,
My system
XP2200
Albatron KT600 Motherboard
1 gig 400mhz ram
2x80gig hd 8mb buffer
fx5600 video card
liquid cooling
My problem is that the cpu runs at 100% whenever I'm trying to convert from say a 2hr movie in avi to dvd compliant mpeg2.
The software i've tried is Tmpgenc, Main concept, canopus procoder an others.
I've read on this forum of people use systems with xp2xxx or p4 2.x processors taking only 15minutes and running at only 50 to 80%
I've tried overclocking from 1800mhz 266 to 2000mhz 400 but still the cpu runs at 100%.
Could it be the chipset drivers? I've read that if the chipset drivers aren't install correctly or just not installed that the cpu have to work harder because it can't access the memory properly. I have downloaded via drivers from viaarena, the 4in1 version and installed them but when it installs, right before it says to reboot a window pops up that says "should not see me"
Is there a way to check and see if the I/O controller drivers are installed properly? I guess these would be Northbridge drivers?
I will go out and buy a xp3200 if it's going to cut my conversions times for a normal movie from 2hrs to 15 minutes but I just want to make sure that it's not a driver problem first.
Any help would be greatly appreciated
vifa
Results 1 to 14 of 14
15 minutes? You mis-read. Converting a 2 hour AVI to MPEG2 DVD standard will take at least 2 hours for 2-pass VBR encode. Factors such as filtering and re-sizing radically affect that time. It will generally always take longer than the movie (can't quite do it in real time, except for CBR encodes).
I think 15 minutes is to rip a DVD5 to Harddrive. Or Burn a DVD at 4x, but 100% most definately not convert a DivX to MPEG2.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Encoding is always going to run at 100% CPU Usage. Simply put because it is a CPU intensive task.
A faster CPU ony shortens the time required to encode.
Why is it worrying you?
Youcan shorten the time required by:
a. Use a motherboard that supports Dual Channel DDR
b. make sure memory is fast enough to match CPU bus speed.
c. fastest CPU you can afford
d. Pentium 4 with hyperthreading and WinXP and a encoder that uses it will be faster too.
If you overclock, watch CPU temps, thats when it generates the most heat.
Good Luck -
You should be worried if your CPU is NOT running at 100% during encoding. It should be using all the CPU to encode.
Using Tmpgenc, you can set the encode to use less CPU by setting it running at lower priority. But this will prolong the encoding. I usually have them run at high priority (100%) and let it run overnight. An average about 11hrs if you set it to encode at maximum quality.
My system: Intel 2.8GB HT, 1GB memory. -
Originally Posted by vuphan
Priority has to do with WHO gets the CPU time. -
Originally Posted by MpegEncoderWant my help? Ask here! (not via PM!)
You're asking the wrong person for "why" ... I never ask why ... I just report the results ... ask old Billy G. for why his OS sucks when it comes to 100% optimal performance/productivity. I see this on WinME and WinXP especially.
Ok, I must have misunderstood.
Just out of curiosity.
The 4in1 drivers for VIA chipsets, one is agp, one is IDE and the other is INF. The agp via driver lets the Northbridge control communication betwee the cpu and the video card. The IDE allows the Northbridge control communication between the CPU and the IDE bus (does this include the ram i/o?) is this correct? And i'm not sure what the inf one does.
If I go to IDE controller it shows primary ide, secondary ide and VIA busmaster. Is this correct
Sorry if I got off the forum topic
vifa -
Who knows what kind of tasking scheme is going on there?
It's all cool -
Originally Posted by vifa84
The IDE is part of the Southbridge. -
Besides that, context shifts take time/resources.
I'd assume these two factors account for some of the difference between running TMPGenc on an otherwise idle system at normal vs high priority. -
Originally Posted by eas
Try this sometime: Open task manager, Encode a file, look in task manager and compare the CPU time used by the coder to actual time that the encode took. See if there are any other processes that have large chunks of CPU time. That will tell you if you have a problem to fix.
What do i need if CPU usage goes 100% when video editing?
By NaHLiJ in forum Newbie / General discussionsReplies: 19Last Post: 28th Dec 2013, 19:13 -
CPU gets really hot (>100°C !) and computer turns off... Thoughts?
By sincostan45 in forum ComputerReplies: 24Last Post: 16th Aug 2010, 23:45 -
DVD shrink using 100% of cpu power, how is that possible?
By aslan in forum ComputerReplies: 10Last Post: 24th Sep 2008, 09:51 -
Stop VLC from using 100% cpu time
By rock.freak667 in forum ComputerReplies: 13Last Post: 4th Apr 2008, 20:56 -
CPU usage goes to 100%
By Tbag in forum ComputerReplies: 21Last Post: 18th Jan 2008, 09:59
