  1. How do I calculate the length of a movie when encoding in TMPGENC seeing that it just show the total frames?
  2. If NTSC, 30 frames per sec, 1800 frames per minute, 108000 frames per hour and so on.
    Feb 2001
    Say the movies's got 30 fps (NTSC) and total number of frames = 300 000 then you just divide 300 000 with 30, giving you the number of seconds in the movie = 10 000.
    Divide 10 000 with 60 and find out how many minutes it is. 10 000/60 = 166,666666666
    Well the movie's 166,7 minutes, but that might not be enough accurate?
    Divide 166,666666 with 60 and find out how many hours.
    166,666666/60 = 2,7777777
    It's 2 hours.
    2,777777777-2 = 0,7777777
    then multiply 0,777777 with 60 to find out how many minutes that is. 0,77777777*60 = 46,666666666
    2 hours 46 minutes.
    But that might not be accurate enough either, so substract 46 from 46,6666666 and multiply with 60 to find out how many seconds.
    46,66666666-46 = 0,66666666
    0,6666666*60 = 40
    So the movie's exactly 2 hours, 46 minutes and 40 seconds.
    Basically, frames/fps/60 will give you the time in minutes
  4. Or, if you have a calculator with sexagesimal (?spelling) notation (most to all scientific calculators), all you have to do is press a button and it will give you the answer...
    Also, the framerate for NTSC is 29.97 frames a second not 30. The makes a difference when you consider the whole length of the movie.
    e.g., 300 000 frames:
    in 29.97 fps = 2h 46m 50s
    in 30.00 fps = 2h 46m 40s (i.e., 10 seconds LESS)
    This is important if you are trying to manually sync audio and video. You must use the correct framerate (29.97).
    Regards.
    Michael Tam
    w: Morsels of Evidence
    Feb 2001
    Yes, ofcourse I didn't think about that, people should stop saying 30 fps, since it really isn't.
    What I'd like to know though, is, why is the framerate 29,97 and not 30? huh..
    /Johan
