the DAT file i am trying to convert is the title menu with thumbnails of a VCD i made with NERO. i want to use this picture as my label on the VCD. here's what i use now and get. i use TMPGE to convert it to an MPG. then i use the program KONVERTER to convert the MPG to a JPEG but when i finished the picture is EXTREAMLY blocky. i know there is a better way but how? someone said on here about something else about changing file extentions but how would i do that if thats all i need to do??....
ok. now i'm a little nieve here but what do you mean by Print Screen? do you mean actually printing the screen or is Print Screen a program???........
Display the image.
Press the button named "Print Screen" on your keyboard. An image of the screen has now been copied to the clipboard.
Open up an image editing proggy like Paint Shop Pro and "paste".
Regards.
Michael Tam
w: Morsels of Evidence
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
Nero Vision to convert .dat file to DVD disc - AUDIO ISSUE
By tlj in forum Video ConversionReplies: 1Last Post: 31st Dec 2007, 16:32 -
converting .DAT file to readable jpeg
By illyad in forum ComputerReplies: 4Last Post: 23rd Oct 2007, 04:14
