Guys:
I just got the Epson R200 and I got the surething CD/DVD Labeler 4.0 Delux.. Ican't find the template for R200 printer for direct CD/DVD printing...Please help me to find the correct template or if someone has created one for this printer, Can I get it???
Thanks in advance..![]()
Voodoo...
Results 1 to 12 of 12
Is there a setting for the Epson 960? It may work.
I have a similar problem with the R800 I just bought. The Epson Print CD software doesn't support business card CD-R media! I complained to Epson and they told me to buy Discus ($40 disc printing software) as it supports business card media. I think it sucks that you buy a $400 printer and the software that comes with doesn't print on a somewhat popular format especially when the 8mm cd adapter is shaped to fit a business car cd.
I'd rather have a bottle in front of me than a frontal lobotomy. -
Thanks for the response..
I tried that template and everytime I try to print it, printer asks me to close the the CD/DVD tray as it was looking for the paper instead of CD/DVD. I also selected CD/DVD on the printer property instead of any paper size and still didn't do any different..
Thanks...
Voodoo!!! -
Here ya go, you also should have did a search for it! About 20 post down from the index page is the Epson 200 Cheaper printer thread, which is where I found this. Also if you would check the surething forums, it's in there too.
See post about SureThing template for the Epson R210, 200, 300, 310
https://www.videohelp.com/forum/viewtopic.php?p=838394#838394 -
Thanks anyway..I did read the entire thread last week..I tried to e-mail him but I can't find it..I sent him a private message..I dont know if he has received it or not...This is the reason i'm posting it again...
Make sure that when your printing that you select manual, not only in surething. But also in the epson setting's.
Where do you find the template for the Epson 960, guys? I have been using the Epson program to do my DVD labels but it is rather limited. Thanks in advance.
Even with the R300 template, you must set the paper to "manual" and "cd/dvd". Just like the tutorial YukonXL posted. Else it will prompt you for paper.Originally Posted by matrix_voodoo
thanks guys...I just downloaded the templates from Pete's web site I will check it out tonight..
Hawseman:
I think that was my part of the problem.. I never changed the paper to "manual"...
Thanks again...
Voodoo!!!
Epson R200, new cheaper disk printer?
By The village idiot in forum MediaReplies: 309Last Post: 26th Mar 2012, 09:56 -
Win7 drivers for the Epson R200?
By MrSpeed in forum MediaReplies: 0Last Post: 27th Apr 2010, 04:50 -
Epson R200 printer and DVD art
By dymx in forum ComputerReplies: 4Last Post: 8th Jul 2008, 11:57 -
Growing very tired of Epson's R200 - R220
By stiltman in forum MediaReplies: 25Last Post: 25th Jun 2008, 23:58 -
Installed R260 Epson, and the print CD keeps recognizing my old R200
By faramith in forum MediaReplies: 11Last Post: 2nd Dec 2007, 18:29
