I am using an ATI WONDER VE ( I know it's cheap but I am trying to make the best of it ), I am capturing audio using "Line in," and the program I am using to capture audio and video is VirtualDub.
The video quality looks just as good as I would like it to look. But the audio has been a different story. Whenever I record from a cable source, the audio always has a hissing type noise in it. The audio meter is always set at 3/4 the meter and I always normalize the audio afterwards to 95% in CoolEdit. So, I then converted the audio in my captured video to wave using VirtualDub and then I opened the wave file in CoolEdit. Inside CoolEdit, I removed the hissing noise from the audio and I multiplexed the audio and video in TMPGenc to convert it to an XVCD with a audio bit rate of 224. But now the audio sounds somewhat squeaky and "lifeless" during dialogue and not near as good as regular t.v. audio sounds. It pretty much sounds like it is being played through speakers inside a large room ( without any echo though ). Not completely squeaky either, but I do notice a "schler" sound after each word ( almost like the actors had speech problems ).
And one last thing, I only notice these problems when playing my VCD in a dvd player connected to a Sony Surround Sound system. And I know there is nothing wrong with the sound system because dvds, cds, and t.v. sounds perfectly.
If you can help me with this problem I would do my best to help you with any problems you are having. I really need help and I've been looking for solutions for a very long time. THANKS!
When you remove the noise in cooledit, first of all make sure you select a section that is just hiss, then got to noise reduction and get profile from selection. Don't remove the noise yet, exit out, select the entire wav, go back to the noise reduction, under the graph type thingy is a slider, reduce that (i use 50 - 70%), then apply, afterwards normalize the wav and save. If you still aren't happy do it again (from the original wav) and reduce the slider. You can also try playing around with the FFT size (don't go above 12000).
I just wanted to clear something up....what is normalizing? And btw, i originally recorded with the line-in slider all the way up so how do I normalize this type of wave?
what audio meter is set at 3/4 then? did you calibrate audio input to avoid clipping?
Wouldn't it be an idea to use the optical inputs on the soundcard (If there are any)? that way there shouldn't be any added hiss.
Audio desync problems when capturing with Fraps
By ecjezl in forum CapturingReplies: 4Last Post: 29th Jun 2011, 22:48 -
Problems Capturing from Vidoenics MX-1
By John Duvall in forum CapturingReplies: 0Last Post: 15th Dec 2010, 07:04 -
Canopus ADVC110 w/Power Director audio stutter problems when capturing?
By popflier in forum CapturingReplies: 7Last Post: 6th Mar 2010, 03:48 -
Capturing problems
By dbrunton in forum CapturingReplies: 9Last Post: 27th May 2009, 13:09 -
Sorry HV20 more capturing problems!
By rhodesy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 14th Jun 2007, 06:54
