Oh yeah..and you get to keep the menus![]()
Results 31 to 39 of 39
Is there anyway to get this new prog to go more than 4 passes? As I have said, I have CCE 2.5 and when I set it up (thanks to the tips above by soundforbjt!) it only allows me to select up to 4 passes. I usually try for 5 to set things straight, especially if I am doing a LARGE project.
Boy do I love my avatar! -
i have a problem with this software. finished the whole process with no problems. its works great in powerdvd, however on my standalone pioneer dvd player there is no sound. this player has played every other dvdr i made with various transcoder programs. however this one doesnt seem to work. i went through the install steps as posted in the doom9 forum. i cant post in the doom9 forum about this since i just signed up to their forum and it makes you wait 5 days before you can post. so if anybody has any ideas what could be causing this or if you can post in the doom9 forum asking about this, please do so. running cce sp 2.50, newest version of avisynth, and i extracted the enitre dvd2avi dg into the avisynth plugins folder. used the three step process of dvdrb and it went through with no problems or errors.
This was mentioned in the tread over at doom9, the long and short is really anything over 4 passes seems to be overkill already so he didn't put an option in there. After 4 passes its really a dimishing returns type thing.Originally Posted by tsantsa
Really 4 passes? whew, I do 2 and 3 on a long movie. -
just 2 or 3 passes? What about a movie that is 3 hr 20 mins? I thought 5 passes sets the optimum bitrate?
I may have to give 2 or 3 passes a shot, save a little time!Boy do I love my avatar! -
New Version out now...
In the new version there is a setting button to use with CCE. In the box there are 3 options. VBR_Bias and Qualiy Prec...What are the best settings for these? (the last setting is VBR Passes...I know what that does...)Boy do I love my avatar! -
why bother bumping such an old thread?Originally Posted by zgrm100
lol, that's what I thought
but maybe there's a new version out though the last I see was 24th July
right-click relatively slow
By alintatoc in forum ComputerReplies: 10Last Post: 3rd Apr 2010, 11:28 -
Is it possible to re-arrange right click
By mn072065 in forum ComputerReplies: 2Last Post: 11th Jun 2009, 22:20 -
Click encode and nothing happens.
By painofmind in forum ffmpegX general discussionReplies: 7Last Post: 5th Jan 2009, 15:26 -
Possible tool from jdobbs for blueray to dvd5/9 avchd backup.
By freebird73717 in forum Blu-ray RippingReplies: 12Last Post: 30th Sep 2008, 02:18
