OK, my issue is this.
Assume I have 1 show (in this case Doctor Who), which is made up of 4 episodes(with each episode being approximately 24 minutes each). The main menu allows you to "Play all", which will cycle through all 4 episodes, during which the standalone DVD player indicates a total "Title" length of approximately 1 hour 40 minutes total. AND YET, if you go to the "Episode Select", and select (for example) episode one, the player indicates a total "Title" length of ~24 minutes (depending on the episode).
Now, you can assign the individual episodes to individual timlines, or put all 4 episodes in one timeline. The problem is - there doesn't seem to be a way to do BOTH, without creating 5 timelines total (effectively doubling the amount of space used, as far as Encore is concerned.)
So, my question is this: is there a way to author the menu system to allow Encore to view the episodes as individual "Title"s (when selected from the Episode menu) and yet see them as one "Title", when selected via the "Play all" option?
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Encore increasing timeline size
By koberulz in forum Authoring (DVD)Replies: 47Last Post: 9th Nov 2011, 11:19 -
Encore adds only video to the timeline, not audio.
By Koppel in forum Authoring (DVD)Replies: 2Last Post: 6th Feb 2010, 09:28 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 06:51 -
Encore CS3 - deletes part of video from timeline during build?!?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 11th Nov 2007, 13:53
