Below is the log file. I copied this file from a bin file. The strange this is, I did this iwth 2 files. One is OK, but this one isn't
guido
############### New MPEG File ###############
File: D:\Download\alt.binaries.images\sinterklaasconfera nce.2003.javier.guzman.deelt.uit\TM_RW_2.mpg
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
******** Demultipexing original mpg file
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file D:\Download\alt.binaries.images\sinterklaasconfera nce.2003.javier.guzman.deelt.uit\TM_RW_2_DVD.mpv.. .
File D:\Download\alt.binaries.images\sinterklaasconfera nce.2003.javier.guzman.deelt.uit\TM_RW_2.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 307285
System headers = 2
Padding Stream packets = 3, total bytes = 4621
MPEG Audio stream 0 packets = 26688, total bytes = 61195584
Video stream 0 packets = 280595, total bytes = 642001307
Saving stream 0xC0 into file D:\Download\alt.binaries.images\sinterklaasconfera nce.2003.javier.guzman.deelt.uit\TM_RW_2-0.mp2...
Summary:
MPEG Packs = 307285
System headers = 2
(Total size: 681MB, Duration: 00:03:12, Rate(MB/Min): 212.19)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 58MB, Duration: 00:02:08, Rate(MB/Min): 27.03)
******** Multipexing elementry streams
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [mplex] File D:\Download\alt.binaries.images\sinterklaasconfera nce.2003.javier.guzman.deelt.uit\TM_RW_2_DVD.mpv unrecogniseable!
INFO: [mplex] File D:\Download\alt.binaries.images\sinterklaasconfera nce.2003.javier.guzman.deelt.uit\TM_RW_2_DVD.mpa looks like an MPEG Audio stream.
**ERROR: [mplex] Unrecogniseable file(s)... exiting.
System.IO.FileNotFoundException: Could not find file "D:\Download\alt.binaries.images\sinterklaasconfer ance.2003.javier.guzman.deelt.uit\TM_RW_2_DVD.mpg" .
File name: "D:\Download\alt.binaries.images\sinterklaasconfer ance.2003.javier.guzman.deelt.uit\TM_RW_2_DVD.mpg"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileInfo.get_Length()
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
Seems to me the file isn't a VCD.... try encoding it again or try demux and remux the fileFile: D:\Download\alt.binaries.images\sinterklaasconfera nce.2003.javier.guzman.deelt.uit\TM_RW_2.mpg
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0Greatings,
Yf -
I had the same problem with a bin file. My solution was to mount it with daemon-tools and then convert it to a "real" mpeg with vcdeasy. Then it was ok. Since your movie is already on cd just use vcdeasy.
MEGui FREEZES!!
By mark63534 in forum Newbie / General discussionsReplies: 0Last Post: 23rd May 2010, 21:43 -
AVI Freezes up
By surffx in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2010, 06:49 -
my computer freezes
By bits27 in forum MediaReplies: 20Last Post: 9th Sep 2009, 01:35 -
XP freezes momentarily
By sdlehman in forum ComputerReplies: 12Last Post: 11th Aug 2008, 17:01 -
Vcd freezes
By notebookguru in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Dec 2007, 16:00
