I downloaded the new version of dvd shrink and dvd decrypter. I ripped and shrunk the files with the dvd shrink. I saved the files to my desktop. However, it saved like 20 files to my desktop, it looks like some audio and some video. I am trying to burn this with decrypter but I have no I idea how to. Did I not save these correctly? I have read the guides and I have loked through the forums but it doesn't make sense. I have even done some on the dvd decrypter but it doesn't look like the files are supported. What am I doing wrong? Can I burn from dvd shrink now. If not, how can I burn from the dvd decrypter. I also have dvd x copy platinum. Can I use dvd shrink and then use the xcopy for my burner. If so, how because I am still having to go through the first step which is the ripping part.
You can rip to ISO with Shrink and have decryptor burn it, all in one shot.
Just choose ISO in shrink under target drive. -
Exactly...if you have the newest version of DVDShrink....your new chain of events will be:Originally Posted by warmagain
1)Lose the previous "files" and start over again.
2) DVDShrink
3) DVDDecrypter (to burn the .iso image the new DVDShrink creates) -
sj022698,
It's kind of strange that DVDShrink didn't create both those folders for you automatically. It must be a setting you need to make.
Create two folders: VIDEO_TS and AUDIO_TS (make sure to name them with all caps). Then place all the files that the programs created and place them in the VIDEO_TS folder. Note that the AUDIO_TS folder remains empty. Keep it 'cause some older players won't play without it.
Then burn both those folders as data files. *The complete folders.
Hope this helps.
DVD Shrink and IMG Burn
By tcory in forum DVD & Blu-ray WritersReplies: 10Last Post: 9th Jan 2011, 15:25 -
Ripping with SHRINK then BURNING with IMG burn
By efiste2 in forum DVD RippingReplies: 10Last Post: 17th Apr 2010, 01:39 -
Movie Shrink & Burn 3.0 - Anyone Familiar With It?
By AllenM in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2008, 18:26 -
Any way to get DVD Shrink to burn faster then 2.5x?
By happydog500 in forum DVD RippingReplies: 1Last Post: 1st Oct 2007, 00:50 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 04:22
