Hi all,
Is there a way to create a pin-code or security code for a DVD? I need to create privileged access to DVDs I'm authoring so that only certain people can view the content. It would require the user to enter a pin code via their remote control before being able to view content. I've seen this feature in the hidden features of some DVDs (like T2). Does anyone know which authoring program I should use for this?
High level authoring here it appears.
This shit is beyond me but now that you have piqued my intrest i may try it when i get time.
Some help.
From what little i understand about the DVD command structure, it would appear you are playing with GPRM's (General Parameter Registers)
Logical AND function perhaps.
Scenarist : http://www23.pair.com/pcrowley/frmanual/SenaristNT_Procedure.pdf
GPRM's
http://www.dvd-replica.com/DVD/gprm.php
http://www.dvd-replica.com/DVD/vmcmdset.php
http://www.dvd-replica.com/DVD/setgprm.php
IFOEdit may be your best bet here.....good luck. !
If either of you guys get it to work, please post instructions on the board!
looks like I'll be picking around in IFO Edit tonight...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I think this may be helpful...
http://www.mediachance.com/dvdlab/tutorial/keypad.html
...at least if you use DVDLAb. I use and love it. For $100 I don't know of any software that can do as much of the pro-grade fancy stuff! Even $500!I'd rather have a bottle in front of me than a frontal lobotomy. -
Keep in mind that this is only good for entertainment value and will *not* keep anyone from viewing your footage if they're really determined to do so. The code stops them from doing it on a dvd player, but a quick rip later and everything will be there on their hard drive, completely unencrypted. If you're looking for *real* security, then the only way to do it is to distribute a data dvd that contains encrypted or passworded files/archives. DVD video is unencrypted by design, except for CSS... and you see how long that worked.Originally Posted by bironsFight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
You could always have a first play with a series of easter eggs that have to be pushed in sequence, but what they hay keep in mind what haloblack said.
thats actually kinda cool.. it would work well for dvd's that kids shouldnt be watchingOriginally Posted by YngwieJM
TMPGEnc Authoring works 4 - Access is Denied (Error code 0x80070005)
By The Roo in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2021, 18:34 -
Power Suppy 20 Pin and 24 Pin
By jollyjohn in forum ComputerReplies: 16Last Post: 3rd Jan 2011, 21:06 -
Motherboard 8 pin connector...
By rubberman in forum ComputerReplies: 15Last Post: 5th Jan 2010, 21:24 -
Removing Dvd Pin?
By Paulus29 in forum DVD RippingReplies: 3Last Post: 30th Sep 2008, 11:15 -
24 pin PSU for a 20 Pin motherboard; Doh!
By Will Hay in forum ComputerReplies: 7Last Post: 5th Mar 2008, 12:02
