My system has a DVD-ROM and a DVD Burner as well as a CD-RW. I was wondering what IDE drive order would be best for on-the-fly DVD copying.
Nothing can stop me now, 'cause I don't care anymore.
With 4 choices; Primary IDE, Boot-master, CD-RW-slave. Secondary IDE, DVD burner-master, DVD ROM-slave. With most newer MB's it doesn't really make much difference. If you are really concerned, get a seperate PCI IDE controller and put them all as master.
If your doing on the fly dvd to dvd copying then its best to put the dvd-rom as slave on the primary and the dvd writer as master on the secondary and cdrw as slave on the secondary,you dont want the secondary ide being used by both dvd devices at the same time while writing and copying.Pci ide controllers are not very good with cd/dvd.
I've got my burner as master and reader as slave on IDE 2. Nearly always burn direct (on the fly) and have never had a problem. It might depend on your config (memory, cpu). Try a couple of burns and see.
XP pro, sp1
512 ram AMD 2600. -
Originally Posted by johns0
Regards!Where is the Deadly Viper Assasination Squad, when you need it ? -
IDE data transfer speed is controlled by the slowest device on that channel(primary or secondary). You should never put a CD/DVD drive on the same channel as a HD. Most CD/DVD are ATA33 and most HD's are ATA100 or 133. placeing your DVD on the same channel as your HD will slow down the HD.
Recommended software and PC configuration for true HD captures
By MoreQsThanAs in forum Newbie / General discussionsReplies: 4Last Post: 31st Oct 2011, 11:12 -
Codec configuration problem?
By Phantomht in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2011, 11:50 -
Configuration of x264vfw using AVICOMPRESSOPTIONS
By Lena_2011 in forum Newbie / General discussionsReplies: 0Last Post: 26th Jan 2011, 03:18 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 21:05 -
MKV2AVI best configuration
By katalogas in forum Video ConversionReplies: 0Last Post: 15th Jun 2010, 05:38
