Would Somebody pleae help?? Errors and No Luck???
I just bought a HP pavilion with HP400i burner and a case of TDK DVD-R, I bought DVD Cloner II, and also downloaded 1Click DVD, plus the DVD Decrypter and DVD43, I have NTFS and Win XP, Last couple of days have been hell trying to backup a commercal Movie. What is the deal? would one of you experts tell me what I need to get/do?
DVD Cloner does not provide good enough guides and how to, and no media gauidance? AM I just out of luck with my TDK DVD-R?
If I don't hear back in the next 24hrs from DVD Cloner, I'll be demanding a refund: :?
Results 1 to 10 of 10
Download both DVDDecrypter (you got that one already) and DVD shrink. Both are available for free and both have numerous guides on this site. Go to the tools section, download them ,install them, read the guides, and then come back if you can't get them to work. They are pretty much idiot proof IF you take the time to read the guides.
That would be my suggestion.
Tom
Oh, and one more thing. Always pick up a few RW discs so you don't make coasters until you get your technique down. -
You might try using the freeware DVDshrink. It's easy to use and there are plenty of guides. Also you might try a few RW DVD's so you don't expand your coaster collection any more. If you're just starting out, study the guides to the left, there's a lot to learn.
Edit: jtommyj, I guess were thinking the same thing, good advice, though. -
Thanks to those replying to my frustration?
Again: Is it true that I can not copy on to TDK DVD-R, or at least not using the HP 400i? It seems kind of odd??? Should I just return them?
If that is the case what Media should I buy instead??Thanks -
don't hear back in the next 24 hours going to demand a refund, lol. should of never bought that shit. should of did a little research and you would have saved some money and gotten dvd shrink. don't know what your problem is because you haven't explained it. what are you steps? copying dvds has came a long ways in the last year and it has gotten really simple. so if you are having problems maybe this is to much for you.....
How Big A Boy Are Ya? -
@redwudz Brilliant minds must think alike LOL
Diginetman- 400i is a + burner so those discs aren't compatible. They are - and you need +.
Tom
Where do you shop (?) and I'll tell you what discs to get . -
Tom:
Thanks for your patience in responding professionaly...
I bought the DVD-R and the HP PC at Costco. I did not notice any other type of DVD Media?
I guess per your advice I'll I need are some DVD +R? right?
RichDVD- I mean DVDCloner II, The one that is full of error messages and no good guides..Thanks -
Yeah, go to your local BestBuy, Costco, Office Max or Office Depot and pick up a 5 pack of DVD+RW to practice on and take back what you can of the TDK DVD-R's or sell them to a friend or something. Then get yourself some DVD+R also.
How to become a computer expert
By freebird73717 in forum Off topicReplies: 7Last Post: 30th Dec 2009, 21:39 -
FLV expert help
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2009, 05:08 -
who is here from uk and is a ripping expert
By lóreal in forum Off topicReplies: 7Last Post: 21st Mar 2008, 19:23 -
Need Major help from an expert!
By jbartosh in forum MediaReplies: 38Last Post: 23rd Oct 2007, 12:45 -
Is this possible? MPC expert please
By ferry1 in forum Software PlayingReplies: 3Last Post: 8th Jun 2007, 18:09
