I would just like to see someones output on this and the way they do it before i look at the tutorials. I have a video that is (MPEG) format and i was wanting to burn it to a dvd+r. What are the steps involved in it and what are they. Thanks for the help.
If it's DVD compliant and the right size, load it into TMPGEnc DVD Author, author, then burn. If it's not compliant, then you read the tutorials.
1. composite and edit it
2. encode it
3. mix and sync audio - master for dvd , encode audio
4. make menus and author dvd (get graphics from graphics dept)
5. test
6. write to DLT (if a master)
7. burn and/or duplicate and/or send out for stamping (if a master)
8. get graphics dept to make up disk and cover designs ..
suggest reading the tutorials first though .. anyway ...
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 13:28 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 05:05 -
How to make such DVD?
By Remyisme in forum Newbie / General discussionsReplies: 9Last Post: 27th Jul 2009, 20:57 -
Best software (pref freeware) to make a music DVD that will play in a DVD
By Trollheart in forum AudioReplies: 10Last Post: 16th Jul 2009, 16:12 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10
