  1. Hello All,
    I started using AC3filter because I was having an audio sync problem when converting a perfectly good movie (audio was in sync to start with). The problem I'm having now is that the audio is too quiet. I've tried all the tips suggested in the guide (turn the normalize off, increase the gains, turn on/off DRC) but no effect.
    Any suggestions
  2. you can try increasing the bitrate of the ac3 file. 192-256 kb/s is dvd standard.
    I always import my wave files into goldwave and increase the volume before converting to ac3.
