Hello Everyone,
I have SONY NS715P DVD Standalone Player, and I'm trying to convert my VCD MPG1 format to DVD.
I know the safest way is to conver the MPG1 format to MPEG-2 format with 720x480 29.97fps format.
However, my VCD resolution size only half of the 720x480, and it takes alot of time to convert to higher resolution.
I do see a guide that showed you to merge mpeg1 format together, then convert the sound to 48000. Then use TMPEGENC to author the DVD, but I can never get this to work. I have totally how to get this method to work to save time.
The current convert method I use is use TMPEGEnc to conver my combined mpeg1 to MPEG-2 format using the DVD(NTSC) setting in TMPEGEnc, but this method takes alot of time, because the resolution goes up to 720x480, but my original VCD mpeg-1 format is only half of that. Is there a way to lower the resolution to the DVD mpeg-2 compatible format?
Thank you for your time.
MPEG-2 on a DVD can be 352x240 (which is the same resolution as VCD)
You can also use 352x480 or 720x480
but if your source is VCD then try MPEG-2 at 352x240
If you are using TMPGEnc Plus 2.5 there is a WIZARD MODE template for this MPEG-2 resolution called NTSC (low resolution)
Try that and it should work A-OK
Please note that you will loose some quality when doing the conversion but if you use a high enough bitrate it will be minimal.
I'm not sure what is a good MPEG-2 bitrate for this resolution but I'm guessing that 2000kbps should be good enough.
Cineform Neoscene and Prem Pro CS3.2 questions/Quest
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 33Last Post: 4th Sep 2011, 22:04 -
My quest to get quality HD video with FLV. Help!
By terminalh in forum Video ConversionReplies: 29Last Post: 5th Aug 2009, 00:47 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
