I have this rip of a dvd that is very dark, I need to know if there is any way to brighten this movie up. Thanks Cosmo![]()
Crank the brightness up on your monitor. Thats the easiest way. You could alter the brightness in QT or something but thats a lot of work.
Is it just the rip thats dark, or is the original dark too?If it isn't broken, take it apart and find out why.
blog: deadsierra -
Remember that your Mac's gamma is a lot darker than what the output will look like on a TV. Chances are it will look fine when you play it back on a regular TV set.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
I thought it was the other way around, that the default Mac gamma was lighter than a tv or typical PC monitor?
I do believe that you are correct, although there's always a large chance that I have confused myself again. Apple uses a 1.8 Gamma, while TV's and PCs use 2.2. That should make the TV's output darker, unless I switched the numbers around accidentally. I'd check via the Monitors button on the System Prefs, but Laptops don't get that option.Originally Posted by mhar4If it isn't broken, take it apart and find out why.
blog: deadsierra -
This dvd plays dark on a tv. It looks very dark and hard to see people in the film. All I want to do is find a way to lighten it up. Thanks
If you don't have the original uncompressed source for this DVD, you'll be losing a lot of video quality. You'd have to rip the DVD to DV format using something like Cinematize or DVDxDV. Then, I would use Compressor (distributed with FCP and DVDSP) to encode back to MPEG2, adjusting the brightness, contrast, highlights and gamma filters to get optimal image quality, and then master a new DVD using DVDSP or maybe Sizzle.
A new (well, port of an old) mpeg2-QT program has been posted on Macupdate. http://www.macupdate.com/info.php/id/7439
It includes an imge filter stage, so might be another tool which could prove useful.
Video from a dark basement... any way to brighten??
By liltroysgrl in forum EditingReplies: 16Last Post: 10th Jun 2010, 23:20 -
Digicam-clip way too dark - need to brighten it up.... how?
By Thanh-BKK in forum EditingReplies: 7Last Post: 29th Feb 2008, 18:21 -
Can I brighten the color on a dvd that's already authored?
By ChaunceyK in forum Authoring (DVD)Replies: 4Last Post: 4th Dec 2007, 18:50 -
NEWBIE QUESTION about dark passages in a DVD rip
By pbecks in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2007, 08:50 -
How do I brighten dark video (mpg) files before burning to dvd?
By denise4gb in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2007, 23:17
