I have a vcd that I made with nero that automatically generated the menu page, actually six pages. I want to get a screenshot of the menu, I guess is the best way to describe it. I want to get the menu image so that I can edit it then use it with vcdeasy when I reburn the vcd.
How can I capture the menu image?
I am using VCDeasy v1.1.5.2 and I can't figure out how to do it. I have tried under the tools/mpeg/tools menu coverting the dat in the segment file to mpg. Then I used VCDxmInfo to scan the mpg file and it says it is a still picture, but then I can't get vcdeasy to load it up, nor have I been successful in getting anyother program (mediaplayers or graphic editing programs) to load it. They all say it is unsupported.
VCDeasy under the tools/mpeg STills/ menu I click the input image browse button to load the newly created mpg file and it only allows supported file times and mpg and dat are not on the list. Thanks for any help.
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 02:07 -
Any programs that can extract an .IBQ image file for me?
By Bansaw in forum Newbie / General discussionsReplies: 3Last Post: 17th Jun 2011, 14:03 -
Mplayer image extract: my TGA is blue!
By RogerTango in forum Video ConversionReplies: 0Last Post: 30th Apr 2011, 13:11 -
extract music from bin image?
By pensioner in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2011, 23:01 -
Extract Image from WMV using HEX values?
By phatz in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2009, 14:44
