GOAL: Color Correct using TMPGEnc Color correction filter
DOING: encode AVI (Divx) to MPEG-2 DVD compliant format
WITH: TMPGEnc Plus
VERSION: Version 2.520.54.163
RESULT: Works perfectly when ecoding in CBR, but not in VBR-2pass.
COMMENTS: HOLD ON ! I know shouldn't talk about Divx conversion, but this is not the subject and source of the problem.
I did some color correction using the custom color correction filter avaible in TMPGEnc. It worked encoding in CBR, meaning that TMPGenc applied the color correction settings I did (better contrast, ajusted the Hue..etc).
I did the exact same thing BUT instead encoded in VBR-2 pass. TMPGenc did not apply the color correction at all.
Is this a BUG or normal ? I have the impression it is normal.....
thanks !
Results 1 to 1 of 1
General Color Correction
By elmuz in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2011, 15:51 -
Increasing color depth and sampling for color correction
By poisondeathray in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2009, 09:06 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
Color Correction for DV
By bsuska in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 23rd Oct 2008, 17:24 -
[SOLVED] TMPGEnc DVD Author doesn't like VBR??
By Taeran in forum Authoring (DVD)Replies: 5Last Post: 19th Sep 2008, 18:11
