I use DVD Shrink 1.37 to rip DVDs and I can't get speeds over 3500KB/s while using my Pioneer DVR-105.
My system is the following:
Athlon XP 2600+
1GB Corsair DDR400 Dual Channel
80GB ATA/133 - Win XP
60GB ATA/133 - Data
80GB SATA - DVDs
Radeon 9800Pro 128MB
Pioneer DVR-105
I also have a machine running a P4 2.8GHz with a Lite-On DVD-/+RW with 512MB Corsair DDR400 and it rips at over 10,000KB/s at times.
Could the slow speed on my XP machine be due to the XP chip or the actual Pioneer?
Anyone with insight is welcomed!!
Lots of DVD rom's are locked at 2X for ripping, Lite-on's are usually recommended as fast rippers. Having said that, check to make sure that DMA is enabled for your drive.
"Art is making something out of nothing and selling it." - Frank Zappa -
DMA is enabled on all my systems.
I didn't know that about a locked speed, is there any way to change that?
Or would the only way to bypass the speed restrictions is to get a Lite-On?
Also, I've noticed that my Pioneer DVD-RW drive is less prone to getting errors while ripping and/or burning DVDs. Does ripping at a higher speed also increase the chances of getting errors in the actual rip?
Thanks again! -
Install some hacked firmware for the drive maybe, do a web search. It's not without risk though.Originally Posted by danfront
Lite-on or one of the other unlocked drives. Do a forum search for fast ripping DVD-roms, it's been covered several times.Or would the only way to bypass the speed restrictions is to get a Lite-On?
It shouldn't, if it does then there's something wrong.Does ripping at a higher speed also increase the chances of getting errors in the actual rip?
Good luck!"Art is making something out of nothing and selling it." - Frank Zappa -
Incorrect, DVD Roms are not locked, its DVD Writers that are locked on 2x.Lots of DVD rom's are locked at 2X for ripping
Lite-On are supposed to be the fastest drives for ripping. i am a lite-on LTD 165H and achieved a max ripping speed of 15.7x (on a dvd5).
Any DVD ROM drive will do for ripping, lite-on drives will only make a couple of minutes difference at most, compared to other dvd rom drives.
EDIT: My Lite-On 165H has died, im now using Lite-On 166S and have acheived a max ripping speed of 15.9X on my first dvd (dvd5)/ the dvd ripped in just over 3.5 minutes.
Ripping speed for dvd-r
By vcd4me in forum DVD RippingReplies: 10Last Post: 22nd Apr 2011, 05:45 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
DVD Fab v/s AnyDVD Ripping Speed
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 25th Mar 2010, 13:04 -
Question about ripping when internet speed is too slow
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2009, 02:49 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41
