Ive converted a number of dvd's no problem, but occassionally when svcd2dvd gets to the multipexing part its just seems to carry on forever. it doesnt freeze the bar at the bottom is always moving
any help on this problem would be great thanks
Starting SVCD2DVD: v1.51.2.0
Begin time: 9:44:32 AM
******** Ripping SVCD images to get mpegs (VcdXRip)
(Total size: 3173MB, Duration: 00:04:11, Rate(MB/Min): 757.59)
Analysing File: E:\S\vcd_mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:00.4a]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:00.4a]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:07.2b]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:02.0a]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0f.08]
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Error getting mpeg details. (probably due to AC-3 audio)
System.Xml.XmlException: An error occurred while parsing EntityName. Line 1, position 22.
at System.Xml.XmlScanner.ScanNamedEntity()
at System.Xml.XmlTextReader.ExpandLiteral(XmlAttribut eTokenInfo currToken)
at System.Xml.XmlTextReader.SetLiteralValues(XmlAttri buteTokenInfo fld)
at System.Xml.XmlTextReader.SetAttributeValues()
at System.Xml.XmlTextReader.ParseElement()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlValidatingReader.ReadWithCollectText Token()
at System.Xml.XmlValidatingReader.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2b c216f3ce925842 a01d771a37e7320b)
Analysing File: E:\S&H\vcd_sahts101_DVD.mpg
Analysing File: E:\S&H\vcd_sahts201.mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'backward_I_offset': [00:09.0e]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'backward_I_offset': [00:09.0b]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:09.0b]
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.28]
Analysing File:E:\S\vcd_mpg
-->Processing 5 mpeg files.
############### New MPEG File ###############
File: E:\S\vcd_mpg
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
******** Demultipexing original mpg file
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file E:\S\vcd_DVD.mpv...
File E:\S&H\vcd_sahts101.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 358022
System headers = 1
Padding Stream packets = 4063, total bytes = 4585159
MPEG Audio stream 0 packets = 34629, total bytes = 79404297
Video stream 0 packets = 323392, total bytes = 735313623
Saving stream 0xC0 into file E:\S\vcd_mp2...
File E:\S\vcd_s101.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 358022
System headers = 1
(Total size: 793MB, Duration: 00:02:11, Rate(MB/Min): 362.99)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 75MB, Duration: 00:00:45, Rate(MB/Min): 99.72)
******** Multipexing elementry streams
System.Threading.ThreadAbortException: Thread was being aborted.
at Microsoft.Win32.NativeMethods.WaitForSingleObject( HandleRef handle, Int32 timeout)
at System.Diagnostics.Process.WaitForExit(Int32 milliseconds)
at System.Diagnostics.Process.WaitForExit()
at ProcRunner.c5b4b7804027a156.160a0bf4de8f6bd0(Strin g d168ac2ed64c4662, String a6a477a49a1a2599, String 450f47a9028f884b, a0efedb9fec1e88f 8b49c96cd0348808, Boolean 74effd3a0f44569e)
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
Not sure m8 but I dont think current version can handle ac3 audio although ChrissyBoy has it down for V2.
It can convert it to ac3 but not from ac3 at the moment.
Maybe thats whats causing it?
BD RB Process BD Files?
By srfdude in forum Blu-ray RippingReplies: 1Last Post: 25th Feb 2010, 09:14 -
Process description.....
By zok4me2000 in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2009, 12:25 -
New Computer > Need New Process
By msdker in forum Newbie / General discussionsReplies: 2Last Post: 14th Mar 2009, 18:18 -
how to keep the HD in my conversion process?
By masadar in forum Newbie / General discussionsReplies: 9Last Post: 21st Dec 2008, 13:41 -
Tweak My Reauthoring Process...
By oohah in forum Authoring (DVD)Replies: 4Last Post: 3rd Jul 2007, 03:18
