When I have a DVD compliant mpeg2 it will convert to DVD in about 40 minutes using Tmpgenc DVD author.
Why then does it take so long to convert the opposite way? ie., .vob files to a DVD compliant Mpeg 2? This would be very little compression wouldn't it? this takes about 30 hours compared to about 6 hours to go to a vcd which has a lot of compression.
Just curious, and hopeing its not PFM.
Results 1 to 19 of 19
In your ear with a can of beer, Up your nose with a rubber hose.
Beeeerrrrr.....MmmmmmmGoooooood! -
How are you converting your VOB's to mpeg? If you're re-encoding then that can take a long time depending your hardware, software and your settings.
Vobedit can extract the audio and video from a VOB, remux to create an mpeg. Womble mpeg2-vcr can create mpegs from VOB's in minutes."Art is making something out of nothing and selling it." - Frank Zappa -
you can also de-multiplex the vob files using tmpgenc, but when you rip the dvd to your hd, make sure to turn off file splitting in dvddecrypter.
Originally Posted by petersenj20"Art is making something out of nothing and selling it." - Frank Zappa
yeah, encoding will be pretty painful.
it takes me about 2 hours to encode a 30 minute avi to mpg2, using 2-pass vbr. I have a pentium 4, 1.4 ghz. -
Allright then. Useing Vobedit I was able to demultiplex the vob. Now I have a .m2v file and an .ac3 file. I seperately demuxed by ticking mpeg and ac3 - respectfully. How do I remux? When I go through file on the menu it only asks for the .m2v file and not the ac3. And it asks for the new vob name. I dont see any guides on the tool page. WTF? Am I retarded and missing something? (Have you seen my baseball?)
What you do next depends on where you want to end up.
If you are aiming for DVD, most authoring tools will accept the elementary streams (m2v/ac3).
If you just want to have a muxed video file to play on a PC, you will need an encoder that will accept ac3 streams. TMPGEnc has an AC3 plugin that will allow it to read the ac3 audio file. Then you can simply merge the two back to one.
Or you can use an app such as BeSweet to change the ac3 to mp3 (mp2?) or wav and then merge with the m2v in TMPGEnc. -
I'm trying to put vob clips on to DVD. I cant get Tmpgenc DVD author to except them directly. I thought I read somewhere this can be done.
when you try to import vobs into tmpgenc dvd author, are you clicking on import dvd clip or using the other option?
I just made a dvd the other day and imported vobs just fine using tda.
anyway, since you now have an m2v and an ac3 file, you should be able to import the files into tda.
just click on add clip
browse to where the m2v file is located on your hd, for the video portion.
browse to where the ac3 file is located on your hd, for the audio portion. -
To import VOBs into DVD Author, you still need the IFO/BUP file structure. It will not import "bare" VOBs.
I did not use the import DVD option.
Using TDA to import my .m2v stream pops up a window that says it is not mpeg compliant and will not except it. Could I have extracted incorrectly using vobedit?
Will not having the ifo/bup files effect this import of the .d2v stream?In your ear with a can of beer, Up your nose with a rubber hose.
Follows is TDA reports in the details. I redid the demux with vobedit. Still no good. I tried to rename .vob to .mpg no dice. I'm lost.
" *This is an illegal video file
This is an illegal video file.
For DVD-Video you can only use the following video formats:
MPEG-1 Video, MPEG-2 Video
TMPGEnc DVD Author does NOT have MPEG encoding abilities.
AVI format(*.avi),RealMedia format(*.rm),WindowsMediaFile format(*.wmv, *.asf),etc. can only be used after they have been encoded to MPEG-1 or MPEG-2 format.
Users of TMPGEnc DVD Source Creator or TMPGEnc can create MPEG files based on the DVD standard by using the DVD template in Project Wizard.
(To encode in different formats requires the various codecs.)"In your ear with a can of beer, Up your nose with a rubber hose.
try to multiplex the two files before importing them into tda.
open up tmpgenc.
click on file=>mpg tools
choose the multiplex tab
browse to where m2v and ac3 file is located on your hd.
click on start
after it is finished you should have one mpg file that you should be able to import into tda. -
Won't work. I have 5 vob files from a home video that was authored. I have only the vobs. I was able to demux only the first vob (using Tmpgenc Plus) It works fine in TDA. None of the other 4 vobs will demux properly or reload to remux. (I tried Tmpgenc and Vobedit. Both failed)
I am guessing something is wrong with the vobs themselves. I cant recopy the disk as it is at another family members house out of state now.
All the vobs play in Intervideo Win DVD so maybe it is just missing some info. I guess its a lost cause. Is Frameserving and re-encoding my only remaining choice? This will work as I have started to do this once already, but 1 hour into and 29 remaining I cancelled.In your ear with a can of beer, Up your nose with a rubber hose.
I bet you have a single harddrive. So your reading and copy 4 GB's from and to the same drive. I usually take 20 Minutes in TAD for a full homegrown DVD (all fully compleint), using 2 drives. It takes over an hour if I author with VCD's (Audio conversion required). It takes 35 minutes if I go to/from the same drive.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
dvd to vhs recorders and vice versa
By videohell in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Nov 2011, 06:02 -
720p video on a 1080p TV, and vice versa?
By sldvd in forum Newbie / General discussionsReplies: 15Last Post: 16th Jun 2011, 21:21 -
How to convert 5.1 to 2.0 AC3 and vice versa
By lapetite_66 in forum AudioReplies: 5Last Post: 8th Mar 2010, 19:30 -
What is best way to convert vob files from pal to ntsc and vice versa?
By hibbs in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2010, 19:41 -
change avi from 16:9 to 4:3 and vice versa
By slowjoe in forum EditingReplies: 9Last Post: 6th Jun 2007, 07:11
