  1. I am trying to backup my disc 2 of the 4th seasons of Sopranos. I have done all 4 seasons with DVD XCopy with not one problem except this one. I have tried doing this one with DVD Decrypter and then I use the shrink but I get an error saying "it is css copywrited material". If I skip the shrink step and try to burn with the dvd decrypter it says it is an "invalid or unsupported file" I have searched forums and the guides but they don't seem to be of much help. Am I doing the process correctly? Where should I be saving the files to? Also, on the dvd decrypter, I do want to check the "remove macrovision" tab, correct? Is there somewhere I can save it to so that if I click out of a program or have a problem, I don't have to completely redo the process?
    Here is what I've been doing.
    1st step. dvd decrypter and click the file tab under mode
    2nd step. dvd shrink (not working)
    3rd step. burn with dvd decrypter
    It has worked with a few other movies. What is the deal?
  2. The latest DVD Shrink, can also Decrypt. So I would suggest doing everything with DVD Shrink, although I am a huge fan of DVD Decrypter.
