Hello !
I'm using DVD2svcd method to backup some scratched dvd's... cause fast transcoders suckz ...the quality is awful![]()
So i'm trying to use something more "professional" like tmpg or CCE
and both of them as better quality then any "fast transcoders" in the net.
But i really want to know which of them is the best
btw the best version of cce is 2.50 ??? is this true?
... oh i forgot to tell that i have all the time in the world to wait till the conv. is finished
thanx in advance [[]]
when you purchase cinema craft , you will not get version 2.5 .. nor is it the best version .. it is also $1995 .. while tmpgenc is $60
there is also cinema craft basic -- but really for the money tmpg is a extremly good buy, for all the extra tools it comes with .. so is main concept .. specialy for re-encoding mpeg"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Man, this has been one of the most popular questions that I have seen posted in this forum. If you type in CCE vs. TMPGE in the forum search you can see some multi-hread discussions on the subject.
I personally like CCE now only because I found it to be faster from start to finish. TMPGE in my opinion gave better quality but it was too slow using all of the best quality settings that were recommended to me. I suggest trying them both and making your own decision.
Godluck,
VCThis is so much fun! -
I would go with TMPG. You really can't be its quality when you know what
you are doing. It's not a matter of taking someones' template, though some
times, it works, but not always.
You are better off learning how to use TMPG and tweak it then anything else.
I've spent many years with TMPG, and I always seem to come back to it.
Right now, I'm also testing out another encoder (a command-line encoder)
and it's not so bad, but at this current time in testing, I would not sell it. Anyways..
I so much happier w/ TMPG than cce but cce is good too.. just costly. I don't,
I repeat, I don't use CCE (other than for testing and comparison purposes)
because as I've said a moment ago, TMPG is it. You just gotta learn how to
use it and open it's features etc etc. If you are not up to this step or just too
lazy (that's ok too) or just want an easy encoder (quicker response here)
than I would recommend sticking with TMPG :P
Hope that all made some sense and all.
-vhelp -
Originally Posted by vhelp
I prefer using AviSynth scripting and CINEMA CRAFT ENCODER aka CCE because of the speed and the fact that my analog captures are in YUV format and that is the format that CCE works in whereas TMPGEnc uses RGB mode.
Both produce output that I can't tell apart. CCE is much faster though.
I still use TMPGEnc especially when needed to resize "oddball" resolutions like you find in some DivX and Xvid clips.
But apart from the fact that TMPGEnc does resizing for you when it might otherwise be tricky to calculate otherwise ... well I just don't hardly use it no more.
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 23rd Aug 2010, 23:17 -
Cinema Craft Encoder Issues converting to 16:9 etc.
By lapetite_66 in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 20:09 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
