ok, i dnt if u can class this as off the topic but yeah, i need to remove a certian part of a dvd because it is damaged? is there any free ware out there tht will remove it or can i patch it up with any software?
can anyone help![]()
Results 1 to 30 of 45
Do you have the dvd already on your pc ?, and there are just sections that won't play or is it a bad disc.
hardcoreruss is asking you if it is a bad disc. You need to explain how it doesn't work.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
what i mean is, it 2 play the 5 chapter, then it frezze's then goes bk to the first chapter, but all the other chapters work.
Sounds like a faulty disc to me, have you tried cleaning it ?
If the disc does not play and you have cleaned it, it is faulty take it back to the shop or buy a new one.
I remeber reading on here about people cleaning the disc with "Brasso"
Maybe a forum search will turn something up. -
Certainly not talking about spelling/english/grammar classes...Originally Posted by Mr anderson
makntraks -
have you tried decrypting the dvd with all possible means?
try Dvd Decrypter, Smart Ripper, Dvd Shrink etc.. and if problem still persists, its a bad disk. -
I had a disk that was damaged. it was a CSI disk.
DVD Shrink could not re-author as it would fail at the same point. When I decoded using DVD Decryptor the fault was not there. Can't exlain why this was so. But it is worth you trying. However I suspect that if the disk is proper damaged then you have had it! -
Mr anderson wrote:
yep been there, dne tht?
makntraks
like im going to take help from a monkey! ehehehhehehheehehheh -
...what question mark?
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
yeah there is a mark on the underneath part of the disk! now is there a way of just removing just a chapter?
....a question mark Mark in the right place place.
You're only a few pieces of DNA away buddy...Originally Posted by Mr anderson
makntraks -
1st to da monkey nice come bk lol, only one chapter is mucked up
I lost my idiot translator. Sorry.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
you will have to be more specific if you want anyone to help you.
please provide some more details -
Ok first of all its not my disk, the underneath of the dvd there is a Scratch, so wht I am asking here is there a way of removing the 5th chapter & keeping the rest of the dvd? Ive seen it done somewhere just cant remember where?
have you tried some cleaner? if it is scratched...you might be able to clean it enough to get the data off
