Ok here it is! I convert avi to mpg with tmpgenc and then burn with nero, the problem i am having is some movies i convert to vcd and burn they play fine and some play but then suddenly speed up while playing then the sound is way off for a minute or 2 then back to normal for about 10 minutes then it does it again, HOW CAN I SOLVE THIS PROBLEM---------PLEASE-------------and oh i am using the apex 500w dvd player, THANK YOU
Results 1 to 1 of 1
HDPVR, need help bad!
By James5955 in forum Capturing and VCRReplies: 26Last Post: 10th May 2011, 11:58 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
my new pc......not bad...
By khalid81 in forum ComputerReplies: 4Last Post: 29th Sep 2009, 16:41 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 10:07 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 19:45
