Hi, I don’t know whether this topic has been posted before. But currently I have problem in capturing video from Handycam to PC, especially for the video quality.
For your information, I’m using Sony 8mm Handycam, Video card Nvidia GeForce2MX-WinFast/Leadtek for capturing, PII-333 Mhz processor, 256 Mb memory and 30 Gb 7200 RPM Harddrive, software for capturing : AMCAP version 1.00 from Microsoft which is standard bundled package with the Video card. Can anyone in this forum help me how to increase the quality for this video capture ?
And also when I convert using VCD cutter from AVI to Mpeg, the process hang at the middle. Any one could help me ? Or suggest the good quality AVI to Mpeg convertion program.
Thanks in advance for your help.
Just warning you that you might get shouted at a little cause this forum is all about that topic
Anyway, get virtualdub or AVI_IO for capturing. Allows you to multi-segment capture (files greates than 2GB), and get a copy of either HUFFYUV or PicVideo MJPEG (capture codecs). I personally frameserve this captured file to panasonic encoder using avisynth though it's easier to use vdub, both of these frameservers will allow you to clean up the video with noise reduction, and cut out the bits you don't need. As you'll probably get a lot of tape hiss on the audio track, save out the audio to a WAV file using VDUB and use Cooledit to reduce the noise, then add it back to your video. Finally encode in your encoder of choise. All the guides for these are either here (look left) or at doom9.net
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 11:49 -
VHS to DVD conversion- capture is way too dark
By kzip in forum Capturing and VCRReplies: 11Last Post: 2nd May 2009, 22:39 -
Not happy with Hi8 to DV capture/conversion results -- Suggestions welcome!
By Hi8 ripper in forum Capturing and VCRReplies: 7Last Post: 9th Jan 2009, 19:21 -
C-it WebCam Capture (Xirlink) Video Conversion
By PalPart in forum Newbie / General discussionsReplies: 0Last Post: 10th Aug 2008, 12:08 -
Best Practices for Video Capture and Conversion
By GregK in forum Newbie / General discussionsReplies: 2Last Post: 23rd Nov 2007, 12:17
