This program is working well for me except for one thing. When I author a DVD and try to insert my own background picture, the program crashes. If I don't change the background picture I can burn the dvd fine. This is the error signature:
AppName: wcreator.exe AppVer: 2.0.14.42 ModName: ntdll.dll
ModVer: 5.1.2600.1217 Offset:00033aed
The instruction at "0x771dee24" referenced memory at "0x0000000c". The memory could not be "read".
I'm running Windows XP Pro on an Athlon XP 3000+ with 1gb of Hyper-X RAM. Has anyone else run into this? Are there any updates available for WinDVD Creator? Thanks for any help/info you can provide.
Sorry for reopening an almost 2 years old topic, but I'm having the same issue with WinDVD Creator...
Does anyone knows the solution? I'm using WinXP SP2, DirectX 9 at an AMD Barton 2500+
My WinDVD Creator is Version 2.5B014.494C00 Eval -
Guess might be conflict with whatever your system uses to view the type of picture you're importing. Try another picture format?
AVIdemux keeps crashing
By gastrof in forum Newbie / General discussionsReplies: 2Last Post: 31st Jan 2012, 13:32 -
MeGUI crashing
By socrates in forum Video ConversionReplies: 0Last Post: 10th May 2011, 04:49 -
x264 keeps crashing
By MR 3 in forum Video ConversionReplies: 6Last Post: 17th Jan 2010, 14:29 -
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 05:54 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 17:04
