Im trying to convert a VCD to DVD using TMPGEnc I have an Athlon 1500XP with 256MB ram and its taking 2.5 hours is this about right
All help gratefully accepted
Results 1 to 15 of 15
it depends.....
you didn't specify what type of bitrate or dvd specs you are using.
are you converting to CBR, CQ, or VBR?.....704X480, 352X480, 352X240, or PAL specs? -
sorry about that Im new to this but I know im converting to Pal 16:9
Just want to know if its common for it to take so long rather than me being stupid and not ticking something in the settings -
well...that's not much added information
but if I had to guess, I'd guess you were using a template thru the wizard, which would mean you'd be going from vcd resolution to dvd resolution....
and judging by the time it's taking on an amd 1500, perhaps you're even using VBR...
and if so, then the time it's taking you isn't too bad
I have a P4 2.4Ghz, and if I use 2-pass VBR an hour of video will take nearly 2 hours to convert. If I use CBR it takes less then 50 minutes. CQ just slightly longer.
and I'm assuming if you have a vcd you're converting, it's around an hour long...you said how long the conversion took but didn't supply the duration of the source video.
you'll find that you'll get more helpful and specific answers here if you supply more specific information -
Originally Posted by ZippyP.
so I guess there is never ever an issue about ntsc>pal conversion....pointless to consider it
....and there is never ever an issue about GOP headers with various dvd authoring programs.....pontless to think about
....and vcd video always has perfect contrast, brighness, color saturation, edge sharpening and of course can never ever have it's appearence improved by filtering.....pointless to even try
...at least it's pointless in a zippy world
in the real world, another pointless action is a person speaking in absolute terms about the subjective nature of video, and whether or not someone else is "wasting" time trying things different in that subjective arena. -
mmasw,you are talking about doing fixes,vcd conversion to dvd is still pointless.
Unless you are "correcting" (*) the video, re-encoding a VCD to make a DVD is pointless.
* Correcting includes changing framerate, GOP headers, colour, contrast, brightness, saturation, edge sharpening, filtering etc.
The chances that the original poster is actually trying to do any of the above is pretty slim."Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by johns0
however....the re-encoding necessary for some of those 'fixes' isn't pointless
and as long as we're all be technically accurate : changing audio from 44Ghz to 48Ghz is technically "vcd conversion to dvd"....so you're technically wrong.
I believe you might mean mpg1>mpg2 conversion as being the 'pointless' endeavour -
I agree that the original poster most likely had no intention of doing these things.
I would point out that both you and johnsO used the term "vcd conversion to dvd " which would technically be defined by simply resampling the audio from 44Ghz to 48Ghz.
that's splitting semantical hairs to be sure, however it did allow me to lob a couple of snide bombs your direction.....it was a slow morning... -
Originally Posted by jimmalenko
sorry that I posted this looks like ive started WW3.Seriously though thanks alot I am new to this and a lot of the stuff goes way over my head but as in everything with a bit of help and a lot of practice i will get there.
PS You guys give each other a big hug Im sure you are all right lol -
Originally Posted by mikey388"Art is making something out of nothing and selling it." - Frank Zappa
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 10:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
