i read more on this and wnat to know is it the way i am converting that is causing this program or is the the MEDIA i use i use MAXELL CD-R74 cds? so the MAIN quesiton is is the the MEDIA? or the ENCODING?
Honestly, both...bad/incompatible media can cause, or the fact your player doesnt like CDRs, I always CDRWs, especially if you are just starting out & in testing phase. Makes sense too, if you mess it, you havent made a "coaster".....yes encoding (however, would need to know more about your enitre process to diagnose further) can cause this as well, if your bitrate is too high for your player. I would recommend always starting with standard VCD spec first on a CDRW, make sure that works first.....then experiment/adjust your settings from there...
i start off using VCDIMAGERGUI and encode to AVI to another AVI and change audio to 4800mhz or whatever it is then and then i do a direct stream of the video so the video stays the same after that is done i use TMPGENCODER to convert to MPEG i use the system + video choice i guess i use all DEFAULT settings because i dont change anything then use NERO to burn the VCD and i use default settings... any suggestions or what do i need to change
How do i load a template? sorry nto to sure on how to do that?? let me know thanks
Sony Vegas Pro 11 Question: Video in Preview and Finished Render "Choppy"?
By MoreThanLuck in forum EditingReplies: 7Last Post: 31st Dec 2011, 20:17 -
MKV stops
By kcmccombs in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2011, 22:17 -
Question about how antivirus stops autorun/exe on USB
By jimdagys in forum ComputerReplies: 5Last Post: 23rd Feb 2010, 17:19 -
Question about audio conversion to put VCDs on DVD
By jimdagys in forum Video ConversionReplies: 5Last Post: 28th Sep 2008, 22:07 -
Burning Stops at about 23% ?
By dagerousdave in forum DVD & Blu-ray WritersReplies: 8Last Post: 20th Aug 2007, 12:29
