Being desperate to get away from the Ulead stuff, which is giving such migraines I'm afraid I'll start peeing blood soon, I've been using the TMPGEnc suite of stuff.
Allright, here's what I did.
I've got some SVCD-complaint MPEGs of a TV show.
Add them into TMPGEnc DVD Author, create menus and all that. Create files to hard drive and then burn them.
I burned them to a DVD+RW because it was a test. I've tried 2 things, and here's what happened.
1: I put the DVD+RW into my DVD player. It comes up to the menu and looks great. I can play movies, and I can hit individual chapters. But no audio. Convinced that it must be something with my system, I insert another DVD, but I get noise.
2. I put the DVD+RW into my PC. I fire up Intervideo WINDVD and it works fine. That happens if I play it off of either the disk or the VIDEO_TS directory.
I checked it when it was in my DVD player, and when I hit the audio button, it told me it was MPG audio. Is that my problem?
-Joe
The audio in the original mpeg needs resampling from 44.1khz to 48 khz to make it DVD compliant.
Rock On -
Can your DVD player normally handle MP2 audio? Many cannot, or need to be specifically set-up to do so.
TMPGEnc DVD Author will do this for you anywayOriginally Posted by rockdj99uk
Hmm...let's see here.
Looking at the edit clip screen I see that my audio is MPEG-1 audio layer 2, 48000Hz stereo, 384kbps.
So, correct me if I'm wrong, but it looks like the sampling rate is already fix, right?
That leaves the whole MPG/PCM thing. Is there a way to convert that in DVD Author, or do I need to do that through TMPGEnc?
If I do have to use Enc, how do I do that without (possibly) screwing up the settings?
-Joe
Non-complaint DVD dimensions...can they be converted to complaint DVD?
By snafubaby in forum Authoring (DVD)Replies: 5Last Post: 30th Oct 2011, 09:03 -
Ripping DVDs as MPEGs using TMPGenc --- loss in quality?
By DieselsDen in forum DVD RippingReplies: 5Last Post: 21st Sep 2010, 13:09 -
Non Hdcp complaint probs! with Phillips Dvp5980/5
By hangman960 in forum DVD & Blu-ray PlayersReplies: 13Last Post: 13th May 2010, 14:48 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 11:22
