Hi,
Im looking for some software that would make it possible for me to edit out the start and end titles of some DVD's I have. Is this possible ? if it is please can you give me the name of the best software to try ?
Thanks for the help.
Best wishes Alan
Best wishes Alan
That depends I guess, do you want to keep the original menus?
No? Then try DVD Shrink in re-author mode selecting only the chapters you want.
Yes? Then try TitleSetBlanker for blanking entire VOBs, or DvdReMake for blanking specific cells within VOBs, or Maybe MenuEdit, or if your brave enough try IfoEdit. -
Just a note that DvdReMake can not only "...blank specific cells within VOBs.." but also cut any cell. It could be either end of last one - this way one can remove credits, or start of the first one - to remove intro, or start/end of any other cell. And it will fix everything in vobs and ifo files so that search (fast forward/backward) works fine.
Actually it can even cut motion menu to reduce its size, and (what a surprice
) it will still work.
http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools -
Hi,
Thanks for the help, I will give it a go!
Best wishes AlanBest wishes Alan
Is it ok to reduce dd true hd to 16 bits for dvd mode ac3 in eac3to? yes
By yoda313 in forum AudioReplies: 0Last Post: 22nd May 2010, 19:44 -
Best combination of Sofware and media
By stallion2008 in forum Authoring (DVD)Replies: 8Last Post: 28th Oct 2009, 17:49 -
the best dvd copying sofware?
By gsingh13 in forum DVD RippingReplies: 13Last Post: 23rd Jul 2009, 17:33 -
Vista 64 bits with 32 bits programs
By skaleton in forum ComputerReplies: 9Last Post: 15th May 2009, 12:41 -
New video editing sofware.
By PeterK in forum EditingReplies: 14Last Post: 8th Jun 2007, 14:54
