if i have written on printable media with a sharpie, as i do not own a dvd inkjet printer yet, will i be able to either:
1 - remove the sharpie ink and print using a new printer when i can buy one at a later date, or
2 - print directly on top of the sharpie ink with said new printer without it looking horrible?
if anyone can answer this i would appreciate it!
You can use isopropyl alcohol 90% to get most Shapie ink off. May not get it all off a printable surface, but it should be safe for the disc.
Printable BDR media recommendations?
By rysktkr in forum MediaReplies: 9Last Post: 2nd May 2011, 05:06 -
Best printable media? (Any 100% working brand?)
By Espen in forum MediaReplies: 14Last Post: 24th Nov 2007, 00:09 -
Need recommendation for printable media
By fazza8 in forum MediaReplies: 0Last Post: 23rd Nov 2007, 16:10 -
Dual Layer hub printable media??
By garstan in forum MediaReplies: 4Last Post: 21st Oct 2007, 15:50 -
Best Printable CD media
By r00kie in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2007, 20:39
