Results 1 to 11 of 11
  1. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I'll admit to being spoiled having used DVDShrink and TMPGEnc DVD Author since I have first started backing up my DVD's. I have a question about DVDDecrypter...all of the guides I've read have given me conflicting(at least to me) info...so I need to confirm.
    If I use IFO mode in DVDDecrypter....can I use the VIDEO_TS folder it creates....add my own blank AUDIO_TS folder then burn?
    I've previously used IFOEdit to create and ISO image of what DVDDecrypter created....but that was before I had my B's Recorder Gold software that can burn the AUDIO_TS and VIDEO_TS folders as data.
    Thanks in advance if you can help.
    Feb 2004
    Brisbane, Australia
    whould simply using DVDDecrypter in ISO read mode do? It will rip an ISO to your HD, then you use it again in ISO write mode to put on DVDr.
    Of course it will have to fit.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I need to use stream processing to remove the Philips menu from an RW(or even a straight R) disc. ISO mode copies the unwanted Philips menu.
  4. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Just rip in FILE MODE using MOVIE ONLY and then import the VOB files into TMPGEnc DVD Author.
    Trim the start and end and put your chapters in etc.
    Very simple and easy to do
    - John "FulciLives" Coleman
    P.S.
    I hate anything +R but a friend from Europe sent me some PAL DVD+RW discs because all he had was a Philips stand alone DVD recorder.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    This particular project needs to be on an RW disc and edited with Ulead Movie Factory 2 due to compatibility issues with the recipient of the DVD(ie...a pain in the ass DVD player).
  6. When you use Movie Only, does that rip the subtitles also?
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    The ORIGINAL question was:
  8. Member wulf109's Avatar
    Jul 2002
    DVD Decrypter in ifo mode does not rip a complete set of ifo files to your HD. You cannot burn the VIDEO_TS directory it creates. To open an old one,you don't need an AUDIO_TS folder.
    You would need to use IFOEDIT to create a proper set of ifo files.
    DVD2ONE upto Ver 1.3 will compress from an ifo rip,I don't think any other "compressor" will do that.
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    THANK YOU
  10. Originally Posted by FulciLives
    hmmm.....you have done that without any problems with audio?
    I just tried with a dvd folder I have on hard drive, and while everything loaded ok, trying to move ahead using the cursor in the chapter/edit window caused the program to bog down in the search....to the point of being rather useless unless I had all day to devote to the project.....maybe all week judging by response time.
    I must be doing something wrong....first time ever!
  11. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    It's best to watch the folder on the computer DVD player first and write down where you want the breaks....then type them in. Oh...and if it(DVD Author) asks you if you would like to let the program choose the correct place to insert the break after you've typed the time in....the answer is YES.
    I've also heard of audio problems using DVDShrink while NOT using the original DVD's chapter markers for "start-end". For me this problem is hit or miss.
