I am trying to convert a .vob to an xvid for editing. I can convert the vob ok, and I get an xvid. The xvid plays fine in QT. However, after I edit the file, and delete some scenes and save as a .mov,QT cannot play the resulkting .mov file, and QT quits. Any hints on why this happens, and what to do about it?
thanks
hmmm...no one has any insights? I think this used to work, could it have anything to do with bitrates (about 2000) or having upgraded to QT 6.5?
No idea at all. Sorry. Maybe if you used a codec that wasn't XviD?
If it isn't broken, take it apart and find out why.
blog: deadsierra -
This worked for you before upgrading to 6.5?Originally Posted by ruggerjvd
Which codec are you using in QTpro, to import XivD? I've only tried DivX and 3vix. Divx would try to convert Xvid - problems, while 3vix would appear to import it natively - no problems.
Did you install/re-install the latest version of the import/export codec after upgrading to QT6.5?
I have done similar ".avi" editing in QT6.5, previously - and it was slow as heck on my Dual 450, with such large files!
I seem to recall one problem was when it came time to save. If I chose save as movie - it wold change the file extension to ".mov" If I chose save as source, it would leave the ".avi" extension.
Hav you tried saving both ways, after editing?
Mike"Dare to be Stupid!" - Wierd Al Yankovic -
In QT, I'm not sure what I'm using for codecs. I'm not importing the file, just palying it. this also happened when I used ffmpeg to convert to mpeg4 using the ffmpeg encoders.
As far as i can remember, I used to be able to edit and resave avi's as .movs, and they worked fine. Could it be using too high a bitrate? I will try to reinstall QT 6.3 and see if it works. -
I think I have posted this several times before, butOriginally Posted by ruggerjvd
here we go again:
Do not use XVID out of ffmpegX if you need to edit.
You need to use MPEG-4(AVI) using mencoder.
Go back to ffmpegx,
convert the .vob to MPEG-4(AVI)[mencoder]
take the resulting .avi, process through Divx Doctor II.
Take the resulting QT Movie, edit it as necessary.
Save the file in the format you need, using a good codec
such as sorenson or 3ivx. ( I reccomend 3ivx, search for
my other posts on encoding in 3ivx for HQ settings.)
I have tried the xivd option from ffmpegx, and since it
makes its own proprietary .avi "shell", QT has problems
doing anything with it, ESPECIALLY EDITING, even with
3ivx or divx 5. Better to stay safe with a codec QT likes,
and to ALWAYS make a QT MOV file, rather than try and edit
a "shell" file like .avi. -
QT will not even play any of the DivX or XviD "avi" files unless you have installed a codec - at some time in the past - since neither format follows the MPEG4 "Standard" that Apple uses.
If you have Divx Doctor, then you probably have a version of the 3viX codec installed (they make Divx Doctor).
Since I'm on a PC (at work) I can't remember the exact path to the "Library" folder which holds the files... Library/Application Support/Quicktime??
When playing the movie, you should be able to open the info window and see whixh codec is being used (Divx or 3vix) and infor on size, framerate, etc.
Since you are editing, even minor edits, you should ensure you have an updated codec.
Suggestions for MOV to MPEG4 and AVI converter
By ITemplate in forum Video ConversionReplies: 3Last Post: 29th Jun 2011, 14:36 -
how to save a videoclip in .mov format
By marlo in forum Newbie / General discussionsReplies: 0Last Post: 11th Nov 2010, 01:53 -
Save Xvid from Sony Vegas Movie Studio
By Cazz in forum EditingReplies: 12Last Post: 29th Jun 2010, 12:50 -
Youtube HD mp4 file can't save as mov by quicktime
By yozloy in forum Video ConversionReplies: 3Last Post: 8th Jan 2010, 04:05 -
Mac Conversion from DVD to .Mov? Any suggestions?
By Jeff_NJ in forum MacReplies: 8Last Post: 1st Oct 2008, 16:28
