Hey all, my NEC 1300a (1.09) DVD burner is not picking up in DVD X Copy Platinum. I dont even see it in the list to select burners. It is as if it isn't there. I know someone else with the same problem with NEC but not Liteon burner. Any thoughts, would really appreciated the input. Thanks.
SysSpec: 2200+, 512DDr, WinXP SP1, MSI GeforceFX 5600XT
I don't know if you can make DVD X Copy detect your burner but I use the following method to burn anyway...
When the window pops up showing that the movie is ripped and ready to burn, I simply leave all DVD X Copy windows open (if you close them, the files you have ripped will be deleated), open Sonic RecordNow and use it to burn.
Every time I use DVD X Copy to burn I end up with a coaster. -
Forget DVDXCopy (biggest pile of overpriced buggy junk ever).
Grab yourself a copy of DVD Shrink (latest beta vers.) and DVD Decrypter (both freeware). This will give you a true "one click" solution for free and you will have lots of support from members of this forum & many others.
Dont take my word for it .... Just Ask around, not too many folk here, who use XCopy
Worth upgrading from sony platinum 8 to platinum suite 10?
By helper in forum EditingReplies: 0Last Post: 30th Jul 2010, 00:30 -
DVD Fab Platinum to HD
By mblanco2000 in forum DVD RippingReplies: 7Last Post: 2nd Mar 2008, 15:50 -
dvdfab platinum and dvd hd decrypter
By marioval in forum DVD RippingReplies: 4Last Post: 8th Jan 2008, 14:40 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 20:12 -
Purchasing DVD Fab HD or Platinum ?
By MacPCConsultants in forum DVD RippingReplies: 3Last Post: 1st Dec 2007, 23:21
