  1. I was considering put my second hard disk trough an usb 2.0 adapter, and connecting my dvd rom to the secondary master ide.
    Is that a good way ( performace, data tranfer, etc..) to go??
    Other suggestions to connect my fifth device???
    USA
    Depends if you have any room in your PC case. I use a IDE PCI controller for my extra HD and a CD burner. If you need to go external, I would use a Firewire case, USB2 can be problematic. I have RAID (80G X 2), 80G boot, 80G backup, DVD ROM, CD burner, DVD burner and a Zip drive. Large case, PS and fans.
  3. thanks redwudz!
    one question about the pci ide controller, are too expensive?? is the 5 device recognized with no problems??
    thanks again
  4. a friend of mine and i went in on purchasing 2 of these (buy one get the 2nd half off), came out to costing each of us $11.25 + tax.. very cheap.
    its a promise controller card..
  5. I was searching some information about, and i found this promise ultra 100TX2 ( maybe the same that you are talking about).
    The datasheets says:
    "Ultra100 TX2’s software drivers automatically boost performance for all drives (even SCSI drives and ATA drives on the motherboard controller) installed in your PC by up to 40%"
    its that true??
    or are they just "selling" the product??
  6. Mod Neophyte redwudz's Avatar
    USA
    This is the one I am using. It works for HD's and CD or DVD drives.http://www.computergate.com/products/item.cfm?prodcd=AIDP13TX2 About $35US. The claims of increased speed are a little optimistic. I wonder what they are comparing it to? Mine seems to be as fast as my MB controller.
