I'm downloading a file, but I have no idea what format it is and how I'll be able to play it. I think it might be VCD or something, but I really dont know. Theres a bunch of files that are downloading in a folder.. they go obs-mra.r00 and then the next one would be obs-mra.r01 and so on theres about 54 of them. Also theres a obs-mra.sfv and a obs-mra.rar file. Its suposed to be a movie, but I'm clueless if anybody can explain this I would really appreciate it. Thanks.
theyre "zip" files or "Rars" in your case..
archived... or whatever they calll it..
basically, its one big file (your movie) split into many little pieces in a certain order (most liekly for the purpose of sending/reciecieving issues)
so that it can be put back together in the same order and "viewed"
you need winRAR... i'll let someone else explain it because i always mix shit up..
but its not such a big deal
goodluck
ep -
I see your d/l mystic river from the newsgroups,thats a forum violation and you will probably get a warning.
to answer your winrar question. All you need to do is open the one whose extention is "rar" the program will open the next squentially numbered extentions and extract them to the same folder for you.
Whoops! I wasnt aware of the rules. I'll make sure not to do that again. sorry.
n00b question on format to use
By hbguru in forum Video ConversionReplies: 1Last Post: 28th Jan 2012, 15:08 -
Format Factory Question
By dexterdoo in forum Video ConversionReplies: 2Last Post: 2nd Aug 2011, 14:43 -
Flash Format (FLV) Question
By Ttownboy23 in forum Video Streaming DownloadingReplies: 3Last Post: 21st Apr 2009, 08:34 -
Silly mkv format, hd question.
By adkom in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2008, 04:36 -
FLAC file format question
By Neil_2004 in forum Video ConversionReplies: 3Last Post: 25th Dec 2007, 10:47
