Can you burn a bin to a DVD
Razz
Results 1 to 10 of 10
the bin you refered to probably is a svcd(which is 480x480). You can not burn bin to dvd. But you can extract the file from the bin file. You will get an mpeg file. Then use TMPGENC to convert it to DVD.(Which very time consuming). Or you can try convert the audio from mpeg file to 48Khz then burn the mpeg file onto DVD as Data. Most DVD Player now can play mpeg file as long it has 48KHz audio.
most films today should be straight DVD to BIn!!!
The electronic components of the power part adopted a lot of Rubycons.
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
will changing bin files to dvd improve sound quality?
By motleycool in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 05:40 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 14:05 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
